Lafkis
DNS Rewrite like in Adguard?
Fri Nov 11, 2022 10:31 am
Hello, is it possible to do something similiar as DNS Rewrite on Adguard?
I would like to forward all intranet traffic like this:
10.0.4.100:8118 -> asset.management.local
10.0.4.100:8001 -> network.management.local
etc.
Is something like this even possible? I don't know what's the technical term to this, as I can't find any information for DNS Rewrite function on anything else other than Adguard.
normis
Re: DNS Rewrite like in Adguard?
Fri Nov 11, 2022 10:32 am
You can use Container function to run Adguard in RouterOS and do it in the same device.
RouterOS does not have any advanced DNS functionality at the moment.
gabacho4
Fri Nov 11, 2022 10:49 am
Can confirm that the feature works wonderfully on an RB5009 ROS 7.6 with container package and a 32 gig USB thumb drive. Couldn’t be happier.
anav
Fri Nov 11, 2022 6:21 pm
Does container run on tile device?
Why the need for a 32Gig thumbdrive??
Znevna
Fri Nov 11, 2022 6:29 pm
No, it does not run on TILE, this was covered before.
I have a 128GB SSD on mine, so a 32GB slow drive is little :)
gabacho4
Fri Nov 11, 2022 6:37 pm
@Znevna I have a 512 gig SSD I was going to play with but thought it was overkill for my immediate needs. Have confirmed that the 5009 recognizes it and all.
@anav the thumb drive, or SSD, is so that you are not increasing the writes to the internal memory of the device which will shorten its lifespan. I bought very low profile thumbs drives so that they don’t accidentally get bumped or broken etc. You can barely tell it’s there at all.
anav
Fri Nov 11, 2022 10:18 pm
Thanks Sir, not even sure I can attach an SSD to my RB450G LOL.or a USB so I am SOL........ (the only arm device I have,,,,,,,, well until I get my hapax3 hopefully soon. I had to buy one after I realized Normis wasnt going to send me one for a xmas present.
Is my microSD card slot in the RB450G an ygood for container use??
gabacho4
Sat Nov 12, 2022 6:28 am
@anav that’s a great question. Not something I’ve ever tried myself as my device has the usb port. In principle I would think the SD card would work but there could be some sort of limitation that I don’t know of. If you insert a card and the go to System -> disk does the SD show up ? If so, how?
Users browsing this forum: eworm, TuxPowered and 43 guests
