KimShaw
RB5009UPr+S+IN having POE-in issues
Fri Nov 11, 2022 7:09 pm
I have RB5009UPr wont accepts PoE-in. Its connected to cisco 3750x. I know cisco works well as it's powering up 8 cameras and it can power up to 24 devices.
Wondering if there any setting needed to be enabled on RB5009 as currently PoE Out is set to auto under all infaces?
Miguelin
Re: RB5009UPr+S+IN having POE-in issues
Sun Feb 19, 2023 6:08 pm
Same problem.
I noticed only eth1 enables PoE-in. All other interfaces (eth2 to eth8) don´t boot up the router.
Is there anyone using it?
Regards
ppireff
Sun Feb 19, 2023 9:44 pm
POE-In is supported only on ether1. The other ports are not hardware wired for it to work. There is a discussion on Reddit about the misleading marketing from MikroTik.
liviu2004
Sun Feb 19, 2023 10:44 pm
PoE in 802.3af/at (ether1), Mode B (ether2-ether8)
Miguelin
Mon Feb 20, 2023 12:18 am
Mode B is pre-standard? I have an Aruba switch which supports 802.3af/at and 802.3af/at + Pre-standard
Users browsing this forum: Bing [Bot] and 16 guests
