MikroNew
Problem connecting tplink extender to hap ac3
Sat Nov 12, 2022 8:00 am
Hi I tried to connect the tp-link extender to the hap ac3, it connects, but there is no internet
anav
Re: Problem connecting tplink extender to hap ac3
Sat Nov 12, 2022 2:14 pm
Are you sure a wifi extender from a different vendor will work well together??
bpwl
Sat Nov 12, 2022 3:59 pm
With wifi extender problems, no internet traffic, first cause is usually the (MT) DHCP server handshake failure to the client device over the wifi extender.
Got no DHCP lease IP address from the hAP ac3? Use a static address. If that works, try some DHCP workaround on the TP-Link.
viewtopic.php?t=116963
broderick
Mon Nov 14, 2022 8:59 pm
Tplink extenders work fine with ISP routers mostly. I set a tp-link extender with an ISP router last week.
Never tried with MK devices though.
bpwl
Tue Nov 15, 2022 3:52 pm
I have the impression (no proof with double check tests done) that it worked in more cases with a different brand DHCP server (like my Draytek router DHCP server) for a Mikrotik AP, than when using MT DHCP, for a repeater (pseudo bridge style) setup with tp-link repeater. But MT AP-bridge with MT station-bridge always works (no pseudo-bridge here).
dave3
Tue Nov 15, 2022 5:05 pm
For what it's worth, I have in the past, connected a tplink extender and it's gotten a dhcp address from my mikrotik router and worked. However, it was connected to another tplink access point that was connected to the wired mikrotik router.
Users browsing this forum: Micat and 11 guests
