dima1002
TG-BT5-IN - Script Move
Sat Nov 12, 2022 9:02 pm
I'm looking for a script that notifies me by email when I move TG-BT5-IN by X or Y axis. is that possible?
E.g. if someone opens the server room door, we would like to be notified.
rextended
Re: TG-BT5-IN - Script Move
Sun Nov 13, 2022 12:38 am
it's a pity I don't have them, I would have seen if something could be done ...
dima1002
Wed Nov 16, 2022 7:49 am
Yes, this is a pity. Check out the Mikrotik Knots. The technique is really interesting.
Can someone else help us? For example, here are some scripts.
https://help.mikrotik.com/docs/display/ ... nt+formats
dima1002
Wed Nov 23, 2022 9:05 pm
can nobody help here?
martc
Sat Dec 03, 2022 11:43 pm
take TG-BT5-in and see whats data get on knot. I dont have this beacon jet. Ordered two pieces and think get after few days...
mikrotik have some example for bluetooth, i think this is enought for start.
martc
Tue Dec 06, 2022 9:30 pm
btw i get tg5-in, little trouble, just sometime need read manual :) this sample script from mikrotik working. i change this for mqtt-domoticz, working fine. react to tilt and switch.
https://help.mikrotik.com/docs/display/ ... r+triggers
and second script is more useful i think, for me not working.. trying find reason why. just return nothin in terminal :)
    # POSIX regex for filtering advertisement Bluetooth addresses. E.g. "^BC:33:AC"
    # would only include addresses which start with those 3 octets.
    # To disable this filter, set it to ""
    :local addressRegex "00:CC:66:88:11:BB"
    # POSIX regex for filtering Bluetooth advertisements based on their data. Same
    # usage as with 'addressRegex'.
    :local advertisingDataRegex ""
    # Signal strength filter. E.g. -40 would only include Bluetooth advertisements
    # whose signal strength is stronger than -40dBm.
    :local rssiThreshold ""
    ################################## Bluetooth ##################################
    :global invertU16 do={
        :local inverted 0
        :for idx from=0 to=15 step=1 do={
            :local mask (1 << $idx)
            :if ($1 & $mask = 0) do={
                :set $inverted ($inverted | $mask)
        return $inverted
    :global le16ToHost do={
        :local lsb [:pick $1 0 2]
        :local msb [:pick $1 2 4]
        :return [:tonum "0x$msb$lsb"]
    :local le32ToHost do={
        :local midL [:pick $1 2 4]
        :local midH [:pick $1 4 6]
        :local msb [:pick $1 6 8]
        :return [:tonum "0x$msb$midH$midL$lsb"]
    :local from88 do={
        :global invertU16
        :global le16ToHost
        :local num [$le16ToHost $1]
        # Handle negative numbers
        :if ($num & 0x8000) do={
            :set num (-1 * ([$invertU16 $num] + 1))
        # Convert from 8.8. Scale by 1000 since floating point is not supported
        :return (($num * 125) / 32)
    :local flagStr do={
        :local str ""
        :if ($1 & 0x01) do={ :set $str " switch" }
        :if ($1 & 0x02) do={ :set $str "$str tilt" }
        :if ($1 & 0x04) do={ :set $str "$str free_fall" }
        :if ($1 & 0x08) do={ :set $str "$str impact_x" }
        :if ($1 & 0x10) do={ :set $str "$str impact_y" }
        :if ($1 & 0x20) do={ :set $str "$str impact_z" }
        :if ([:len $str] = 0) do={ :return "" }
        :return [:pick $str 1 [:len $str]]
    # Find fresh Bluetooth advertisements
    :global btOldestAdvertisementTimestamp
    :if ([:typeof $btOldestAdvertisementTimestamp] = "nothing") do={
        # First time this script has been run since booting, need to initialize
        # persistent variables
        :set $btOldestAdvertisementTimestamp 0
    :local advertisements [/iot bluetooth scanners advertisements print detail \
        as-value where \
            epoch > $btOldestAdvertisementTimestamp and \
            address ~ $addressRegex and \
            data ~ $advertisingDataRegex and \
            rssi > $rssiThreshold
    :local advCount 0
    :local lastAdvTimestamp 0
    :local advJson ""
    :local advSeparator ""
    # Remove semicolons from MAC/Bluetooth addresses
    :local minimizeMac do={
        :local minimized
        :local lastIdx ([:len $address] - 1)
        :for idx from=0 to=$lastIdx step=1 do={
            :local char [:pick $address $idx]
            :if ($char != ":") do={
                :set $minimized "$minimized$char"
        :return $minimized
    :foreach adv in=$advertisements do={
        :local address ($adv->"address")
        :local rssi ($adv->"rssi")
        :local epoch ($adv->"epoch")
        :local ad ($adv->"data")
        :local version [:tonum "0x$[:pick $ad 8 10]"]
        :local encrypted [:tonum "0x$[:pick $ad 10 12]"]
        :local salt [$le16ToHost [:pick $ad 12 16]]
        :local accelX [$from88 [:pick $ad 16 20]]
        :local accelY [$from88 [:pick $ad 20 24]]
        :local accelZ [$from88 [:pick $ad 24 28]]
        :local temp [$from88 [:pick $ad 28 32]]
        :local uptime [$le32ToHost [:pick $ad 32 40]]
        :local flags [:tonum "0x$[:pick $ad 40 42]"]
        :local bat [:tonum "0x$[:pick $ad 42 44]"]
        :put ("$advCount: \
            address=$address \
            ts=$epoch \
            rssi=$rssi \
            version=$version \
            encrypted=$encrypted \
            salt=$salt \
            accelX=$accelX \
            accelY=$accelY \
            accelZ=$accelZ \
            temp=$temp \
            uptime=$uptime \
            flags=\"$[$flagStr $flags]\" \
            bat=$bat" \
        :set $advCount ($advCount + 1)
        :set $lastAdvTimestamp $epoch
    :if ($advCount > 0) do={
        :set $btOldestAdvertisementTimestamp $lastAdvTimestamp
:log info $advCount
dima1002
Mon Dec 12, 2022 7:06 am
this works for me when tilt or impage, unfortunately not yet if you only move it
[admin@Knot] > /system/script/export
# dec/12/2022 06:01:20 by RouterOS 7.4
# software id = LMW4-2MB9
# model = RB924i-2nD-BT5&BG77
# serial number = F5750ECE0D59
/system script
add dont-require-permissions=no name=script4 owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="# Input MAC address of the tag within \"\"\r\
    \n:local addressRegex \"DC:2C:6E:13:15:7E\"\r\
    \n\r\
    \n# POSIX regex for filtering Bluetooth advertisements based on their data. Same\r\
    \n# usage as with 'addressRegex'.\r\
    \n:local advertisingDataRegex \"\"\r\
    \n\r\
    \n# Signal strength filter. E.g. -40 would only include Bluetooth advertisements\r\
    \n# whose signal strength is stronger than -40dBm.\r\
    \n# To disable this filter, set it to \"\"\r\
    \n:local rssiThreshold \"\"\r\
    \n\r\
    \n#enter the subject for the email within the \"\"\r\
    \n:local emailsubject \"RouterOS report!\"\r\
    \n\r\
    \n#enter the email address wthin the \"\"\r\
    \n:local emailaddress \"mail@domain.com\"\r\
    \n\r\
    \n#Script:\r\
    \n################################## Bluetooth ##################################\r\
    \n:local flagStr do={\r\
    \n    :local str \"\"\r\
    \n\r\
    \n    :if (\$1 & 0x01) do={ :set \$str \" switch\" }\r\
    \n    :if (\$1 & 0x02) do={ :set \$str \"\$str tilt\" }\r\
    \n    :if (\$1 & 0x04) do={ :set \$str \"\$str free_fall\" }\r\
    \n    :if (\$1 & 0x08) do={ :set \$str \"\$str impact_x\" }\r\
    \n    :if (\$1 & 0x10) do={ :set \$str \"\$str impact_y\" }\r\
    \n    :if (\$1 & 0x20) do={ :set \$str \"\$str impact_z\" }\r\
    \n\r\
    \n    :if ([:len \$str] = 0) do={ :return \"\" }\r\
    \n\r\
    \n    :return [:pick \$str 1 [:len \$str]]\r\
    \n}\r\
    \n\r\
    \n:local triggernameF \"free_fall\"\r\
    \n:local triggernameT \"tilt\"\r\
    \n:local triggernameX \"impact_x\"\r\
    \n:local triggernameY \"impact_y\"\r\
    \n:local triggernameZ \"impact_z\"\r\
    \n:local triggernameS \"switch\"\r\
    \n\r\
    \n# Find fresh Bluetooth advertisements\r\
    \n:global btOldestAdvertisementTimestamp\r\
    \n:if ([:typeof \$btOldestAdvertisementTimestamp] = \"nothing\") do={\r\
    \n    # First time this script has been run since booting, need to initialize\r\
    \n    # persistent variables\r\
    \n    :set \$btOldestAdvertisementTimestamp 0\r\
    \n}\r\
    \n:local advertisements [/iot bluetooth scanners advertisements print detail \\\r\
    \n    as-value where \\\r\
    \n        epoch > \$btOldestAdvertisementTimestamp and \\\r\
    \n        address ~ \$addressRegex and \\\r\
    \n        data ~ \$advertisingDataRegex and \\\r\
    \n        rssi > \$rssiThreshold\r\
    \n]\r\
    \n:local advCount 0\r\
    \n:local lastAdvTimestamp 0\r\
    \n:local triggerlist \"\"\r\
    \n\r\
    \n:local triggerF\r\
    \n:local triggerT\r\
    \n:local triggerX\r\
    \n:local triggerY\r\
    \n:local triggerZ\r\
    \n:local triggerS\r\
    \n\r\
    \n:local messageF \"\"\r\
    \n:local messageT \"\"\r\
    \n:local messageX \"\"\r\
    \n:local messageY \"\"\r\
    \n:local messageZ \"\"\r\
    \n:local messageS \"\"\r\
    \n\r\
    \n:local 21st \"\"\r\
    \n\r\
    \n:foreach adv in=\$advertisements do={\r\
    \n    :local address (\$adv->\"address\")\r\
    \n    :local rssi (\$adv->\"rssi\")\r\
    \n    :local epoch (\$adv->\"epoch\")\r\
    \n    :local rtime (\$adv->\"time\")\r\
    \n    :local ad (\$adv->\"data\")\r\
    \n    :local flags [:tonum \"0x\$[:pick \$ad 40 42]\"]\r\
    \n    :local fflags \"\$[\$flagStr \$flags]\"\r\
    \n    :if (\$fflags=\"\") do={:set \$fflags \"none - periodically broadcasted payload\"}\r\
    \n\r\
    \n    :local obj \"# \$advCount:\r\
    \n                             time: \$rtime\r\
    \n                             trigger: \$fflags\r\
    \n\r\
    \n\"\r\
    \n    :set \$advCount (\$advCount + 1)\r\
    \n    :set \$lastAdvTimestamp \$epoch\r\
    \n    :set \$triggerlist \"\$triggerlist\$obj\"\r\
    \n\r\
    \n:set triggerF [:pick \$triggerlist ([find \$triggerlist \"free_fall\"]-0) ([find \$triggerlist \"free_fall\"]+9)]\r\
    \n:if (\$triggerF=\$triggernameF) do={:set messageF \"\$triggernameF\";:set 21st \"not00\";}\r\
    \n:set triggerT [:pick \$triggerlist ([find \$triggerlist \"tilt\"]-0) ([find \$triggerlist \"tilt\"]+4)]\r\
    \n:if (\$triggerT=\$triggernameT) do={:set messageT \"\$triggernameT\";:set 21st \"not00\";}\r\
    \n:set triggerX [:pick \$triggerlist ([find \$triggerlist \"impact_x\"]-0) ([find \$triggerlist \"impact_x\"]+8)]\r\
    \n:if (\$triggerX=\$triggernameX) do={:set messageX \"\$triggernameX\";:set 21st \"not00\";}\r\
    \n:set triggerY [:pick \$triggerlist ([find \$triggerlist \"impact_y\"]-0) ([find \$triggerlist \"impact_y\"]+8)]\r\
    \n:if (\$triggerY=\$triggernameY) do={:set messageY \"\$triggernameY\";:set 21st \"not00\";}\r\
    \n:set triggerZ [:pick \$triggerlist ([find \$triggerlist \"impact_z\"]-0) ([find \$triggerlist \"impact_z\"]+8)]\r\
    \n:if (\$triggerZ=\$triggernameZ) do={:set messageZ \"\$triggernameZ\";:set 21st \"not00\";}\r\
    \n:set triggerS [:pick \$triggerlist ([find \$triggerlist \"switch\"]-0) ([find \$triggerlist \"switch\"]+6)]\r\
    \n:if (\$triggerS=\$triggernameS) do={:set messageS \"\$triggernameS\";:set 21st \"not00\";}\r\
    \n\r\
    \n}\r\
    \n:if (\$advCount > 0) do={\r\
    \n    :set \$btOldestAdvertisementTimestamp \$lastAdvTimestamp\r\
    \n}\r\
    \n\r\
    \n:if (\$21st=\"not00\") do={/tool e-mail send to=\$emailaddress subject=\"\$emailsubject\" body=\"\$triggerlist\"} else={:put \"21st octet does not have triggers detected!\"}"
[admin@Knot] > /system/scheduler/export
# dec/12/2022 06:01:25 by RouterOS 7.4
/system scheduler
add interval=10s name=schedule1 on-event="/system script run script4\r\
    \n/system script run test" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=nov/12/2022 start-time=19:33:27
[admin@Knot] >
normis
Mon Dec 12, 2022 8:52 am
We have several videos about using the TG-BT tags, maybe it helps: https://youtube.com/playlist?list=PLXr- ... D2Cgi5pOez
dima1002
Tue Dec 13, 2022 3:51 pm
Thanks, I had already looked at some.
Is there possibly also support for money? or can one inquire there somewhere?
dima1002
Thu Jan 12, 2023 4:38 pm
I'm sorry. But can anyone really help me with this topic? Or does someone know a support?
rextended
Thu Jan 12, 2023 4:53 pm
Even if someone has the good will to help you with the scripting, if they don't have the device they can't...
Contact support@mikrotik.com directly and let us know what they reply to you.
dima1002
Thu Jan 12, 2023 9:54 pm
I'll buy you a device if you help me :-)
dima1002
Mon Mar 06, 2023 9:52 pm
Many thanks to Mikrotik Support, they helped me a lot. Thanks
Here's how it works:
# Input MAC address of the tag within ""
:local addressRegex "AC:2C:6E:13:05:9E"
#enter the subject for the email within the ""
:local emailsubject "Move"
#enter the email address wthin the ""
:local emailaddress "mail@domain.com"
#Script:
:local flagStr do={
    :local str ""
:local triggernameF "free_fall"
:local triggernameT "tilt"
:local triggernameX "impact_x"
:local triggernameY "impact_y"
:local triggernameZ "impact_z"
:local triggernameS "switch"
    as-value where \
:local advCount 0
:local triggerlist ""
:local triggerF
:local triggerT
:local triggerX
:local triggerY
:local triggerZ
:local triggerS
:local messageF ""
:local messageT ""
:local messageX ""
:local messageY ""
:local messageZ ""
:local messageS ""
:local 21st ""
    :local rtime ($adv->"time")
    :local fflags "$[$flagStr $flags]"
    :if ($fflags="") do={:set $fflags "none - periodically broadcasted payload"}
    :local obj "# $advCount:
                             time: $rtime
                             trigger: $fflags
    :set $triggerlist "$triggerlist$obj"
:set triggerF [:pick $triggerlist ([find $triggerlist "free_fall"]-0) ([find $triggerlist "free_fall"]+9)]
:if ($triggerF=$triggernameF) do={:set messageF "$triggernameF";:set 21st "not00";}
:set triggerT [:pick $triggerlist ([find $triggerlist "tilt"]-0) ([find $triggerlist "tilt"]+1)]
:if ($triggerT=$triggernameT) do={:set messageT "$triggernameT";:set 21st "not00";}
:set triggerX [:pick $triggerlist ([find $triggerlist "impact_x"]-0) ([find $triggerlist "impact_x"]+1)]
:if ($triggerX=$triggernameX) do={:set messageX "$triggernameX";:set 21st "not00";}
:set triggerY [:pick $triggerlist ([find $triggerlist "impact_y"]-0) ([find $triggerlist "impact_y"]+1)]
:if ($triggerY=$triggernameY) do={:set messageY "$triggernameY";:set 21st "not00";}
:set triggerZ [:pick $triggerlist ([find $triggerlist "impact_z"]-0) ([find $triggerlist "impact_z"]+8)]
:if ($triggerZ=$triggernameZ) do={:set messageZ "$triggernameZ";:set 21st "not00";}
:set triggerS [:pick $triggerlist ([find $triggerlist "switch"]-0) ([find $triggerlist "switch"]+6)]
:if ($triggerS=$triggernameS) do={:set messageS "$triggernameS";:set 21st "not00";}
:if ($21st="not00") do={/tool e-mail send to=$emailaddress subject="$emailsubject" body="TAG MOVED!"} else={:put "21st octet does not have triggers detected!"}
Users browsing this forum: No registered users and 17 guests
