Barak
UserManager v7.6 - Profile limits - Not yet implemented...
Sun Nov 13, 2022 10:57 am
hello friends
I have a problem with UserManager version 7.6
When I create a profile, the limit is not applied to the user
And an error " Not yet implemented..." is also received in the user's web profile
How can I connect the limit profile to the user profile like in User Manager version 6?
Stiflerakos
Re: UserManager v7.6 - Profile limits - Not yet implemented...
Tue Mar 28, 2023 4:37 pm
Same problem here.
Normally counting Data but limits are not applied to the user.
Any idea?
Maybe something with attributes?
servicep
Wed Jan 03, 2024 10:05 pm
You have a solution because I am facing the same situation with V7.13
bpwl
Wed Jan 03, 2024 11:35 pm
Actually the limits via attributes do work for wifi. But the status and numbers are not visible. When the limit (volume quota) is reached, the user then is denied access until the counter in the limit is reset.
I have not found a command to reset. The only way so far is waiting for the scheduled reset. (Allah ... increasing the limit value did work as an immediate workaround (to let the blocked user connect again)
viewtopic.php?t=185562#p1017080
bpwl
Wed Jan 03, 2024 11:50 pm
And be aware of this ... BUG? supposed to be the MAX allowed , no?
But no ... this is not what I thought was logical, the (Max) Rate limit set via attributes is also used as the Min Rate Limit
, set as limit-at
limit-at=30M/30M max-limit=30M/30M ??????????????????
viewtopic.php?t=180603#p1015122
Users browsing this forum: Google [Bot], robibert, Semrush [Bot], ZeeBOB and 119 guests
