complete2006
Wireguard Question
Mon Nov 14, 2022 8:52 am
Hi!
I have a simple wireguard question:
MT-Wireguard VPN Server is running fine
MT-Wireguard Client is running fine (RoadWarrior with dynamic IP).
Communication over the tunnel fine.
How to see on the VPN Server if the client is connected? The tunnel stays always "running" and the only thing at the peer I can see if there is a long time since last handshake.
anav
Re: Wireguard Question
Mon Nov 14, 2022 1:35 pm
Since you have a keep alive set for 25 seconds for example just go to the graph on the WG server and you should see a traffic spike every 25 seconds.
Znevna
Mon Nov 14, 2022 1:44 pm
Or you can monitor that peers IP and if it's down... well.. it's dead, Jim.
Users browsing this forum: johnb175a, pellerb, smirgo and 67 guests
