DotTest37
DDNS Update IP rule on remote router
Mon Nov 14, 2022 4:58 pm
I switched my ISP at home and now it changes public IP once a day.
three of my remote Mikrotik boxes had rules whitelisting my home IP, and now I have to manually edit then.
I know I can make a script on my home box to detect the IP changes and update its rules, but how can i do the same on the remote boxes?
The remote boxes need to know the changes on my home to update their rules.
Any advise?
Thanks!
Sob
Re: DDNS Update IP rule on remote router  [SOLVED]
Mon Nov 14, 2022 6:26 pm
You didn't write what exactly you have. If it's some firewall rule, you can use address list with hostname.
DotTest37
Mon Nov 14, 2022 6:48 pm
I have firewall filter rule.
specifically an input rule that allows my home external IP.
How often does the address list refresh the resolved address?
Sob
Mon Nov 14, 2022 6:53 pm
It uses TTL from DNS record.
DotTest37
Mon Nov 14, 2022 6:57 pm
Testing now, I set a 60 sec TTL and changed my record. I
I will test through the day and report back.
DotTest37
Mon Nov 14, 2022 8:07 pm
Worked perfectly. I added a new public DNS record with TTL 60 sec and I'm using that from Mikrotik.
The DNS record is updated with a sh script that I have running inside a Linux box at home.
Mikrotik is checking the record every 60 secs and updating the address list.
Thanks a lot for the good advise.
Users browsing this forum: Semrush [Bot] and 12 guests
