crovip
Can't open ports like 40317 or 49317
Mon Nov 14, 2022 8:57 pm
Hi, can anyone help me with my issue, regarding opening ports like 40317 or 49317?
I already created NAT rules in the firewall tab, but no luck.
Anything else that I should do ?
Thank you
BartoszP
Re: Can't open ports like 40317 or 49317
Mon Nov 21, 2022 10:36 pm
Could you post your config? That screen does not tell to much.
I suggest using WinBox instead of smartfon to configure your eouter.
anav
Mon Nov 21, 2022 11:34 pm
Users browsing this forum: akakua, raiser and 110 guests
