wire
REST API delete/disable/modify a list of items
Tue Nov 15, 2022 10:47 am
I am attempting at writing a connector for the v7 REST API. Currently wondering if there is any mechanism for deleting/changing a list of similar items.
Documentation for the DELETE verb only mentions deleting by key.
A POST at the (say) ip/address/disable or ip/address/destroy with a .query selector return an empty array [] and not an error, but also don't seem to do anything. (while a print with the same .query does work.
Any help is appreciated.
mrz
Re: REST API delete/disable/modify a list of items
Wed Nov 16, 2022 8:50 am
QUERY is not supposed to work that way.
You should use query to get item IDs, and then use those ids to execute delete.
wire
Wed Nov 16, 2022 9:33 am
Ah, so there is no way to atomically delete a collection of matching items? And why it returns an empty array [ ] if the query isn't allowed?
mrz
Wed Nov 16, 2022 9:38 am
because delete returns ids that i has deleted, since you did not delete anything array is empty.
Users browsing this forum: Jonty and 27 guests
