DarkNate
How do I enable IGMP Snooping when using bridge+VLANs?
Tue Nov 15, 2022 3:46 pm
Crosspost Reddit thread
So I have a single CCR1036 on ROS 7.6 whereby I used this config guide to configure bridge and bridged based VLAN:
viewtopic.php?t=143620#p706998
Also, because MikroTik recommends that type of config for this model:
https://help.mikrotik.com/docs/display/ ... switchchip
Now the good news is, this is working correctly for IPv4/IPv6 traffic unicast. However, the moment I enable multicast carrier on the bridge itself, IPv6 SLAAC/RA/NA/NS traffic all begins to break and no longer works.
So am I doing something wrong with the IGMP Snooping config when using bridge/VLAN? How do I get IGMP snooping to work in the simplest way possible for my VLAN based config?
Below is my config sample export that is working but without multicast carrier enabled.
add frame-types=admit-only-vlan-tagged igmp-snooping=yes igmp-version=3 mld-version=2 name=bridge1 vlan-filtering=yes
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether1 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether6 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether7 pvid=20
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether8 pvid=10
/interface bridge vlan
add bridge=bridge1 comment="Main VLAN" tagged=bridge1 vlan-ids=20
add bridge=bridge1 comment="Management VLAN" tagged=bridge1 vlan-ids=10
/interface vlan
add interface=bridge1 name="Main VLAN" vlan-id=20
add interface=bridge1 name="Management VLAN" vlan-id=10
mike7
Re: How do I enable IGMP Snooping when using bridge+VLANs?
Tue Nov 15, 2022 4:03 pm
Check if "Multicast Querier" is enabled on the bridge.
viewtopic.php?p=906424#p906140
DarkNate
Tue Nov 15, 2022 5:19 pm
Which part of the OP quoted below is not clear to you?
Why would I enable “Multicast Querier” when it explicitly breaks IPv6 SLAAC/NDP traffic?
Users browsing this forum: No registered users and 55 guests
