Rox169
wifiwave2 increase wifi power
Wed Nov 16, 2022 12:30 am
I need increase wifi power on hap AC3 with wifiwave2.I use setting with czech republic on 2,4 GHz only 20 Mhz but one client is to far and is connecting and disconectic all the time. If im not wrong there is no possibility to use superchannel in wifiwave2,
Any advice please?
holvoetn
Re: wifiwave2 increase wifi power
Wed Nov 16, 2022 7:47 am
Too far as in ... how far ?
What's in between access point and client device ?
Especially with wifiwave2 MT made sure no legal limits can be crossed so I am not sure you can "crank up the volume" any further.
chechito
Wed Nov 16, 2022 4:17 pm
Any advice please?
put a different name for 2.4ghz radio ssid and 5ghz radio ssid, maybe your device is sticking to 5ghz radio which has less coverage (but more speed), for high coverage you must use 2.4ghz radio
putting different names makes easier you to verify and controll to which radio are you connected
rextended
Wed Nov 16, 2022 5:11 pm
Nice results for
/interface/wifiwave2 info country-info "United States3"
and
/interface/wifiwave2 info country-info "Canada2"
RESULTS code
 2.4ghz: 2412 MHz      20/40mhz        30 dBm
          2417 MHz      20/40mhz        30 dBm
          2422 MHz      20/40mhz        30 dBm
          2427 MHz      20/40mhz        30 dBm
          2432 MHz      20/40mhz        30 dBm
          2437 MHz      20/40mhz        30 dBm
          2442 MHz      20/40mhz        30 dBm
          2447 MHz      20/40mhz        30 dBm
          2452 MHz      20/40mhz        30 dBm
          2457 MHz      20/40mhz        30 dBm
          2462 MHz      20/40mhz        30 dBm
          2467 MHz      20/40mhz        30 dBm
    5ghz: 5180 MHz      20/40/80mhz     30 dBm
          5200 MHz      20/40/80mhz     30 dBm
          5220 MHz      20/40/80mhz     30 dBm
          5240 MHz      20/40/80mhz     30 dBm
          5745 MHz      20/40/80mhz     30 dBm
          5765 MHz      20/40/80mhz     30 dBm
          5785 MHz      20/40/80mhz     30 dBm
          5805 MHz      20/40/80mhz     30 dBm
          5825 MHz      20mhz   30 dBm
(not a copy-paste error)
holvoetn
Wed Nov 16, 2022 5:28 pm
Something which you should always do when testing such issues.
Rox169
Wed Nov 16, 2022 9:36 pm
I have saparately 2,4 and 5 Ghz, 5Ghz is not available because it is too far.
Rextended thank you it looks promising. Could I find a list where can I see all countries with power and channels?
Rox169
Wed Nov 16, 2022 9:56 pm
In 2,4 ghz it could help there is 10dBm plus in compare with Czech rep. But in 5ghz Im not sure, cod you please explain if I can use 5600 MHz 20/40/80/160mhz 30 dBm DFS (CAC 10 min) this channel? There is same dBm as in Canada 30dBm...I have set skip DSF ALL does it means that I can not use any DSF channels which requires DSF check?
country: Czech
2.4ghz: 2412 MHz      20/40mhz        20 dBm
          2417 MHz      20/40mhz        20 dBm
          2422 MHz      20/40mhz        20 dBm
          2427 MHz      20/40mhz        20 dBm
          2432 MHz      20/40mhz        20 dBm
          2437 MHz      20/40mhz        20 dBm
          2442 MHz      20/40mhz        20 dBm
          2447 MHz      20/40mhz        20 dBm
          2452 MHz      20/40mhz        20 dBm
          2457 MHz      20/40mhz        20 dBm
          2462 MHz      20/40mhz        20 dBm
          2467 MHz      20/40mhz        20 dBm
          2472 MHz      20/40mhz        20 dBm
    5ghz: 5180 MHz      20/40/80mhz     23 dBm  indoor
          5200 MHz      20/40/80mhz     23 dBm  indoor
          5220 MHz      20/40/80mhz     23 dBm  indoor
          5240 MHz      20/40/80mhz     23 dBm  indoor
          5260 MHz      20/40/80mhz     23 dBm  DFS (CAC 1 min) indoor
          5280 MHz      20/40/80mhz     23 dBm  DFS (CAC 1 min) indoor
          5300 MHz      20/40/80mhz     23 dBm  DFS (CAC 1 min) indoor
          5320 MHz      20/40/80mhz     23 dBm  DFS (CAC 1 min) indoor
          5500 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 1 min)
          5520 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 1 min)
          5540 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 1 min)
          5560 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 1 min)
          5580 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 1 min)
          5620 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 10 min)
          5640 MHz      20/40/80/160mhz 30 dBm  DFS (CAC 10 min)
          5660 MHz      20/40mhz        30 dBm  DFS (CAC 1 min)
          5680 MHz      20/40mhz        30 dBm  DFS (CAC 1 min)
          5700 MHz      20mhz   30 dBm  DFS (CAC 1 min)
rextended
Thu Nov 17, 2022 1:12 pm
/interface/wifiwave2 info country-info <insert country name here or press TAB for see the country name list>
skip DFS do not skip DFS check.... skip channels wher DFS is required... on Canada2 and US3 no requirement for DFS is present on any channel...
gotsprings
Thu Nov 17, 2022 3:24 pm
More a fan of shutting things off. Makes it a lot easier to see whats going on... if the thing is THE ONLY THING ON.
mkx
Thu Nov 17, 2022 8:35 pm
Nice results for
The difference between this and "normal" Canada is that Canada2 omits all DFS channels (available in Canada). "Normal" Canada lists channels 5180-5240 as indoor with lower permitted Tx power (24 dBm) ... which is the only big difference (most people try to avoid using DFS channels).
Ca6ko
Long time Member
Long time Member
Sat Nov 19, 2022 8:41 pm
No, you can't. Because your device can operate at a maximum of 26 dBm. This will severely reduce the speed.
In your case, you will get the best results with a directional antenna.
Rox169
Tue Nov 22, 2022 2:30 pm
ok, but 26 dBm is better than 20 dBm. So Canada2 is better choice for me....
Ca6ko
Long time Member
Long time Member
Wed Nov 23, 2022 10:22 am
If you are satisfied with the speed limit of 1-3 mbps, then use it.
Rox169
Fri Nov 25, 2022 4:35 pm
if is going to help to disconnect the device why not.
Users browsing this forum: akkurad and 33 guests
