karthik1810
Cannot access internal web server via domain name & Cannot access VLAN to Internal Network.
Wed Nov 16, 2022 8:27 am
I am new to Mikrotik Router. I'm using Mikrotik RB750Gr3.
My Setup:
Ether 1 = WAN1 (PPPOE)
Ether 2 = WAN2 (DHCP CLIENT)
Ether 3, 4 & 5 = Bridged port ( 192.168.0.1 / 24 ) - INTERNAL NETWORK
VLAN 2 = 192.168.68.1 / 24 - TIME NETWORK
VLAN 3 = 192.168.10.1 / 24 - GUEST NETWORK
Internet Access:
Bridged Port ( Internal Network ) = Access to WAN 1
VLAN 2 & VLAN 3 = Access to WAN 2
Having two problem:
1. Internal and VLAN 2 network cannot access internal webserver via domain name ( ci-my.aleph-labs.com )
2. VLAN 2 network cannot access to Internal network.
Totaly confused for how to proceed further. Please advice on this. Can refer attachement for my config script.
Sob
Re: Cannot access internal web server via domain name & Cannot access VLAN to Internal Network.
Wed Nov 16, 2022 3:06 pm
- Dstnat rules are wrong, if they should work from inside, they can't have in-interface="TM UNIFI". You'll also need hairpin NAT for access from main internal network. More info: viewtopic.php?t=179343
- You need to make sure that you're not marking routing for traffic to internal networks, otherwise it will be sent to internet.
- Your non-existing firewall is not a good thing. See this for some ideas how to improve it: viewtopic.php?t=180838
Users browsing this forum: fhuladaq, Kanzler and 49 guests
