norocel
my clients is virused, help me plees
Wed Oct 10, 2007 10:31 pm
Helo ,
I have mikrotik ros 2.9.27, and 400 windows-xp clients.
A lot of clients are virused and make flood to dns provider servers (udp port 53).
How can i make a filter for this virused clients?
10x in advanced
gmsmstr
Trainer
Trainer
Re: my clients is virused, help me plees
Thu Oct 11, 2007 12:01 am
either block the entire DNS port, or add a rule to add SRC-ADDRESS to any IP that has too many DNS requests.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
norocel
Thu Oct 11, 2007 12:09 am
u can be more specific, pleez?
GuJack20
Trainer
Trainer
Thu Oct 11, 2007 12:32 am
400 PC virused?? U got a nasty neigborhood :(:(:(
My solution would be to desinfect the clients!!
--Do you remember that guy who gave up? Neither does anybody else!
Chupaka
Thu Oct 11, 2007 2:10 am
m.b. New Firewall Rule -> Extra -> Limit
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Thu Oct 11, 2007 1:19 pm
unplug their cable, and if they call to complain - suggest to remove the virus and then internet will be back. i've seen this and it actually works
GuJack20
Trainer
Trainer
Thu Oct 11, 2007 1:28 pm
:wink: :D :wink:
jorj
Mon Oct 15, 2007 10:38 am
Esti din RO ? Daca da, lasa un ym, si te pot ajuta.
You can block the ip of each client suspected of a virus, and they will call you. Just use torch to find out what's happening, and then add a firewall rule with "drop" on a "virused" src-address list. Wich you make by adding the infected ip's to it.
norocel
Mon Oct 15, 2007 1:18 pm
Salut, sunt din ro
Am rezolvat ceva ceva dar nu e foarte bine.
ym: cccblue_suport@yahoo.com
Poate ne sincronizam pe messenger intr-o seara
Multumesc,
jorj
Tue Oct 16, 2007 1:05 pm
k.
You're on my list.
Users browsing this forum: anav, VanceG and 78 guests
