swits1109
Automating DoH
Thu Nov 17, 2022 10:44 am
I have found this awesome guide on how to set up DoH: https://jcutrer.com/howto/networking/mi ... over-https
But, it is a bit out of date and the steps are manual in the GUI instead of automated with a script. Can someone help automate the remaining steps I need in the <> brackets?
/tool fetch url=https://curl.se/ca/cacert.pem
/certificate import file-name=cacert.pem passphrase=””
<ASKS FOR PASSWORD, NEED TO REMOVE THIS PROMPT>
<REMOVE EXISTING DNS SERVERS IF THEY EXIST>
<Add 2 Static DNS Entries for cloudflare-dns.com to Address: 104.16.248.249 and 104.16.249.249>
<ADD DOH SERVER TO https://cloudflare-dns.com/dns-query>
<CHECK VERIFY BOX>
<CHECK ALLOW REMOTE REQUESTS BOX>
kangarie
Re: Automating DoH
Thu Nov 17, 2022 1:09 pm
i think you can just use this script
/ip dns set allow-remote-requests=yes servers="" use-doh-server=https://1.1.1.1/dns-query
no static dns and no certificate validation needed
rextended
Re: Automating DoH
Thu Nov 17, 2022 1:57 pm
Yes, because 1.1.1.1 cert already contain also the IP 1.1.1.1 as alternate name
For example https://one.one.one.one/dns-query do not work without standard server because first must resolve one.one.one.one with the standard DNS.
Sob
Re: Automating DoH
Thu Nov 17, 2022 2:54 pm
@kangarie: "no certificate validation" = any MITM can present fake certificate and then see or even modify everything you're sending and receiving. If that's your goal, fine, enjoy. But otherwise it's better to have verification enabled.
Jotne
Re: Automating DoH
Fri Nov 18, 2022 7:46 am
no static dns and certificate validation needed
As in
(no static dns) and (certificate validation needed) -> You need certificate validation
or
(no static dns) and (no certificate validation needed) -> You dont need certificate validation
As other write. You should have normal DNS setup and working to make sure you use an URL without IP, so that you can use a Certificate with DoO
eworm
Re: Automating DoH
Mon Nov 21, 2022 6:19 pm
You can use the query url with ip address ("https://1.1.1.1/dns-query" ) and enable certificate verification. As the ip address is stored as alternative subject name inside the certificated this works. No static dns required, but you need to import the correct CA certificate (which is "DigiCert Global Root CA" for Cloudflare).
eworm
Re: Automating DoH
Mon Nov 21, 2022 6:23 pm
This should do the job for perfectly secure dns via Cloudflare:
/tool/fetch https://cacerts.digicert.com/DigiCertGlobalRootCA.crt.pem;
/certificate import file=DigiCertGlobalRootCA.crt.pem passphrase="";
/ip/dns/set use-doh-server="https://1.1.1.1/dns-query" verify-doh-cert=yes;
Users browsing this forum: No registered users and 11 guests
