gradash
Can't login by IP to LHG LTE18
Thu Nov 17, 2022 2:05 pm
Why this can happen ? It pings, it works with main router, it gives internet, but i can connect to it only directrly with lan cable.
Config is almost default, just maked bridge with only one erher1 port, added ip address (10.12.12.1), and turned on DHCP server with pool 10.12.12.100-10.12.12.200 for bridge (ether1)... that's all
hecatae
Re: Can't login by IP to LHG LTE18
Thu Nov 17, 2022 9:52 pm
Sorry I missed something, why does a bridge need a 100 IP DHCP range?
killersoft
Sun Nov 20, 2022 6:25 am
Because that's exactly where your suppose to apply the DHCP server if you add a bridge to a physical interface port( because the physical becomes a slave interface), furthermore if you add a vlan to a bridge or physical interface then the dhcp server interface will be the vlan interface.
https://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server
As for not logging in, good chances there is a misconfig in IP settings between device and PC. Or you have mis-configured/disabled access to the router from the interface your on.
See if you can use MAC logon instead ( MAC addr of the physical and or bridge mac )
https://wiki.mikrotik.com/wiki/Manual:Winbox
gradash
Thu Nov 24, 2022 11:42 am
they are in different vlans, but my vlan have access to all, and some other mikrotiks connects by ip..
Users browsing this forum: Bing [Bot], mansuramir and 79 guests
