Alxpv
ROS 7.6 + UserManager 7.6 fails to limit traffic volume by voucher
Thu Nov 17, 2022 6:17 pm
I made a testing config on new RB952Ui-5ac2nD
It has radius + hotspot setup + UserManager 7.6
Generally, it works
BUT
If the user during the session gets kicked off with Transfer limit (set to 250Mb for me), he can connect back and get 250Mb limit one more time. First login attempt after kick off does not allows him to authenticate and on auth [age I see error host (IP) not found, but second consequent attempt of login allows me to login.
I had to add interim update interval and total-limit value to User Group Properties as Attributes that it started to work somehow, as without it it does not worked.
Advertise link I added to be sure the auth window will appear more frequently.
Maybe I missed something in config, please advice
Users browsing this forum: No registered users and 35 guests
