Bab200
Rb4011 switch all to sfp
Thu Nov 17, 2022 7:53 pm
Hi forum, I’m getting more and more used to Mikrotik equipment and like it.
I just got an upgrade to Fiber 10G WAN - my throughput did not increase. Setup is router of the provider (looking at hooking in the rb4011 directly); from there 10G copper to RB4011 sfp port. That works and line is recognized at 10G line.
Set wlan and eth port into bridge but not sfp and I see very low performance sfp port goes max value to 12 to 20 kbps. Or even close to M level.
All eth ports show as RS so go via CPU, right? How can I make them all go via switch and keep sfp as WAN?
Sorry for this, might be a very rookie question. Haven’t found anything that pointed me to a hint.
erlinden
Re: Rb4011 switch all to sfp
Fri Nov 18, 2022 12:01 pm
Would be helpful if you share your current config (/export hide-sensitive file=anynameyoulike), make sure to remove any private information.
BrateloSlava
Fri Nov 18, 2022 1:08 pm
Also write the model of the optical module you have installed.
Bab200
Fri Nov 18, 2022 3:04 pm
As module I’m using a H!Fiber 10Gb SFP+ RJ45 Transceiver, 10Gbase-T SFP+ Ethernet Copper Module that goes currently into the router of the provider.
add admin-mac=48:9F:5A:39:34:D9 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge \
    secondary-frequency=auto ssid=Home wireless-protocol=802.11
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Home \
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.200-192.168.88.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=sfp-sfpplus1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=sfp-sfpplus1
/ip dhcp-server lease
add address=192.168.88.25 client-id=1:30:cd:a7:2d:91:56 mac-address=30:CD:A7:2D:91:56 server=defconf
add address=192.168.88.11 client-id=1:0:12:18:2:75:af mac-address=00:12:18:02:75:AF server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=Europe/Rome
/system leds
add interface=wlan2 leds=wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-led,wlan2_signal4-led,wlan2_signal5-led type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
BrateloSlava
Fri Nov 18, 2022 3:31 pm
As far as I know, such devices are VERY critical to the quality of the cable and its length.
H!fiber 10G SFP+ RJ45
Bab200
Fri Nov 18, 2022 7:01 pm
Just put the Mikrotik next to the router. Was able to increase the throughout by 3 times, so cable length makes a difference. Still directly in the router I get 7x more.
Any idea to increase the throughput?
Users browsing this forum: No registered users and 65 guests
