elico
Rustdesk-server container with many neat features
Fri Nov 18, 2022 2:17 am
Rustdesk is an opensource alternative for Anydesk and Teamviewer (cannot 100% replace Teamviewer but is good enough for the price).
Rustdesk is composed of couple components:
  • A server (api and registration)
  • A relay server
  • A client
  • An installer
I have added a "secure" (password protected) http server to serve the customized installer scripts for both windows and linux desktops.
The software page is at:
https://rustdesk.com/
The source of the software are at:
https://github.com/rustdesk/rustdesk
The installer which I have used couple of it's components is at:
https://github.com/techahold/rustdeskinstall
The sources of my container are at:
https://github.com/elico/rustdesk-server-container
The Rustdesk services( hbbs, hbbr) are listening on ports:
  • 21115
  • 21116
  • 21116/udp
  • 21117
  • 21118
  • 21119
and it cannot be changed for now.
The web server is listening by default on port: 8080 but it's configurable using environment variables.
I will publish a video on how it looks and works later on.
One of the purposes of this container is to give SMB/Enterprises the ability to host an internal RDP and remote support service.
The only option now to publish this service publicly is using a domain name or to customize the installer for an internal one and an external one.
By default the bundled Windows AIO Powershell and Linux client installer script that downloads and installs the service enable direct IP connections and also via a relay.
This is an example on how to spin up this container in cli:
/interface/bridge/add name=dockers
/ip/address/add address=172.20.0.254/24 interface=dockers
/interface/veth/add name=veth91 address=172.20.0.91/24 gateway=172.20.0.254
/interface/bridge/port add bridge=dockers interface=veth91
/container/config/set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/container/envs/add name=rustdesk_envs key=TZ value="Asia/Jerusalem"
/container/envs/add name=rustdesk_envs key=IP value="172.20.0.91"
/container/envs/add name=rustdesk_envs key=DOMAIN value="172.20.0.91"
/container/envs/add name=rustdesk_envs key=RELAY value="172.20.0.91"
/container/envs/add name=rustdesk_envs key=HTTP_ADMIN_USER value="admin"
/container/envs/add name=rustdesk_envs key=HTTP_ADMIN_PASS value="73245937-be70-4921-955d-6cba7e872b18"
/container/envs/add name=rustdesk_envs key=HTTP_PORT value="80"
/container/envs/add name=rustdesk_envs key=ENCRYPTED_ONLY value="0"
/container mounts add dst=/data name=rustdesk_data src=/disk1/rustdesk_data
/container mounts add dst=/public name=rustdesk_public_http src=/disk1/rustdesk_public_http
/container/add mounts=rustdesk_data,rustdesk_public_http dns=172.20.0.254 remote-image=elicro/rustdesk-server:latest interface=veth91 root-dir=disk1/rustdesk envlist=rustdesk_envs start-on-boot=yes
Later on a Video demo
elico
Re: Rustdesk-server container with many neat features
Fri Nov 18, 2022 3:18 am
An example of usage in video of installation and operation at:
https://www.youtube.com/watch?v=DGC_Wt6HX7w
own3r1138
Long time Member
Long time Member
Re: Rustdesk-server container with many neat features  Topic is solved
Fri Nov 18, 2022 6:47 pm
Thank you for all the containers that you created and shared recently. I could certainly use this one too.
Alexybg
Wed Apr 26, 2023 4:05 pm
Is this working.
I have try it today but no image is download from registry-1.docker.io ?
own3r1138
Long time Member
Long time Member
Wed Apr 26, 2023 6:08 pm
1- pull the image with Docker or Podman.
2- save image-name > name.tar
3- use the.tar file to create a container.
fragtion
Wed Apr 26, 2023 6:18 pm
Nice container!!
Alexybg
Tue May 02, 2023 4:50 pm
I have installed it but, not all working fine.
I have use Client connect local to local PC in local network, or outside to outside.
Connection Local to Outside PC or Outside to Local PC
Error Fail to connect Relay Sever .. ?
someone have same problem ?
sebr
Tue May 30, 2023 10:54 pm
Hi
I have the same problem. I switched from a 4G connection where I had no problem with my remote clients being able to connect to my server at home.
Since my remote site switched to fiber with a Mikrotik Hap ac3 router, my clients can no longer reach my server.
If you have an idea I'm a taker for help.
elico
Fri Jun 02, 2023 10:34 am
I will try to test it on a regular container and server first.
If it's the same for both a container and a server then it's something with the rustdesk software and should be discussed in their github issues.
elico
Sat Jun 03, 2023 11:14 pm
OK, SO I have verified this issue.
The way to handle this issue is to define two things:
1. is to always use the relay server in the environment variables.
2. both clients should use the same host domain name, for the local/internal the domain should point to the internal IP
For the external the domain should point to a cname of the MT device or a specific ip address.
With these it works fine both behind nat and also if there is some part of the network that is shared between sites or as simple as connecting an internal PC to a remote one and vise versa.
I will not update the container for now.
jasonwxybj
Fri Dec 01, 2023 7:25 am
I also have the question, how do I do it.
elico
Sat Dec 02, 2023 11:03 am
@jasonwxybj do what?
Users browsing this forum: No registered users and 3 guests
