Techsystem
changing the License key from level 4 to 5 + enable hotspot
Fri Nov 18, 2022 6:23 am
Hello My friends..!
so anyone have any idea about how can i change my router license key from level-4 to 5 , please if there is any link or trusted guide..?
my router is RB951ui.
also how can i enable hotspot on it, there is alot of stuff and video out there but i couldnt find a trusted one..
mkx
Re: changing the License key from level 4 to 5 + enable hotspot  [SOLVED]
Fri Nov 18, 2022 8:08 am
This help page should give you an idea about the whole process of upgrading license.
Licenses (as I hear) don't come cheap, you may find out it'd be cheaper for you to purchase a new Routerboard (with license level 5 embedded, RB4011 and RB5009 both do) instead.
Already license level 4 allows creating hotspot (with lower number of users). Again, hotspot help page should give you idea about how to configure it.
rextended
Fri Nov 18, 2022 3:58 pm
If max 200 concurrent connections, provided by Level 4, are not enough for you,
then it means that you haven't understood that one hAP is certainly not enough for you...
killersoft
Sat Nov 19, 2022 4:14 am
+1 on Rextended's comments.
Your better off spinning up a CHR RoS on a virtual machine and getting a CHR license to manage the hotspot users, than using an under-spec'ed(CPU/mem) device for even 50+ simultaneous users !
Buckeye
Forum Veteran
Forum Veteran
Mon Nov 21, 2022 6:49 am
Specifications
Details
Product code			RB951Ui-2nD
Architecture			MIPSBE
CPU	QCA9531
CPU core count			1
CPU nominal frequency		650 MHz
Dimensions			113 x 89 x 28mm
RouterOS license		4
Operating System		RouterOS
Size of RAM			64 MB
Storage size			16 MB
Storage type			FLASH
What would be the point in level 5 on this platform? Single core 650MHz, 64MG Ram.
Seems like trying to pull an AirStream two axle travel trailer behind a VW beetle.
Users browsing this forum: Amazon [Bot] and 139 guests
