adolfossl
Multiple internet services & Multiple WAN
Fri Nov 18, 2022 2:13 pm
Hello!
I have two wans connected to the mkrotik with 2 independent IPs, currently they work as failover. I would like to be able to access all the services that I have shared (html, ssh, mail server....) independently from each IP. I start to think it's impossible...
I guess my problem will be in the configuration of mangle or in the routes (Pepe is ISP-1 and LTE1 is ISP-2
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=Pepe new-connection-mark=pepe_conn passthrough=yes
add action=mark-routing chain=output connection-mark=pepe_conn new-routing-mark=to-Pepe passthrough=no
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=lte1 new-connection-mark=Vdfn_conn passthrough=yes
add action=mark-routing chain=output connection-mark=Vdfn_conn new-routing-mark=to-Vdfn passthrough=no
add action=mark-routing chain=prerouting connection-mark=pepe_conn in-interface=bridgeLAN new-routing-mark=to-Pepe passthrough=no
add action=mark-routing chain=prerouting connection-mark=Vdfn_conn in-interface=bridgeLAN new-routing-mark=to-Vdfn passthrough=no
add comment="MONITOR Pepe" disabled=no distance=1 dst-address=1.1.1.1/32 gateway=192.168.5.1 pref-src=0.0.0.0 routing-table=main scope=10 \
suppress-hw-offload=no target-scope=10
add comment="MONITOR Vdfn" disabled=no distance=1 dst-address=4.2.2.2/32 gateway=lte1 pref-src=0.0.0.0 routing-table=main scope=10 \
add check-gateway=ping comment="ROUTING Pepe" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.1.1.1 pref-src=0.0.0.0 routing-table=\
to-Pepe scope=30 suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="ROUTING Vdfn" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src=0.0.0.0 routing-table=\
to-Vdfn scope=30 suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="DEFAULT Route - Backup (Vdfn)" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src=0.0.0.0 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="DEFAULT Route - MAIN (Pepe)" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.1.1.1 pref-src=0.0.0.0 \
add check-gateway=ping comment="FAILOVER Pepe" disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src=0.0.0.0 routing-table=\
add check-gateway=ping comment="FAILOVER Vdfn" disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=1.1.1.1 pref-src="" routing-table=to-Pepe \
Thank you
Sob
Re: Multiple internet services & Multiple WAN
Fri Nov 18, 2022 3:49 pm
It's very possible. Your mangle rules seem correct. I'm not completely sure about routes, because I don't use recursive routing often enough myself. As a quick test, you can try these instead of the two (ROUTING Pepe/Vdfn) you have:
add dst-address=0.0.0.0/0 gateway=192.168.5.1 routing-table=to-Pepe
add dst-address=0.0.0.0/0 gateway=lte1 routing-table=to-Vdfn
If it doesn't changes anything, then it's either something else in your config (firewall filter or NAT), or some outside influence (ISP config).
adolfossl
Tue Nov 22, 2022 12:33 pm
Hello everybody again.
Finally, the original config works... but has a stranger problem.....
If I make a direct connection to the Mikrotik (ssh or webmin) through the backup connection it works perfectly. However, if I connect with a computer behind the mikrotik (ssh to a raspberry) the connection becomes very slow. I have discovered that if I have winbox open with torch running on the interface of the backup connection it works fast and stable. Any idea why this happens? Thank you
Sob
Tue Nov 22, 2022 2:11 pm
Fasttrack, probably. Add connection-mark=no-mark to it.
adolfossl
Tue Nov 22, 2022 2:47 pm
Sorry, I don't understand what I should do.
I've done like this and it's still going slow.
/ip/firewall/filter
add action=accept chain=forward comment="pidesktop TCP4000" connection-mark=no-mark dst-port=4000 in-interface-list=WAN protocol=tcp
add action=dst-nat chain=dstnat comment="pi4desktop TCP 4000 --> 22" dst-port=4000 protocol=tcp to-addresses=192.168.90.254 to-ports=22
Sob
Tue Nov 22, 2022 3:15 pm
Do you have rule in firewall filter with action=fasttrack-connection? If so, that's the one you should change.
adolfossl
Wed Nov 23, 2022 11:59 am
Excellent, It's work!!!!!
Thank you very much!!!
Users browsing this forum: No registered users and 17 guests
