pashew
IPsec ping through Main Server
Sun Nov 20, 2022 10:57 am
Greetings,
I have three routers, A B and C.
A=192.168.10.0/24
B=192.168.11.0/24
C=192.168.12.0/24
A is the Main Site that has IPsec with B and C, everything is working fine and I can ping from A to B and from A to C.
But I Can not ping between B and C.
there is a way to ping between B and C by adding policies from both sides, but I want to ping between B and C through A.
there are many topics regarding this issue by using L2tp and OSPF.
is there any way to accomplish it by IPsec itself without using L2tp throw a firewall or route?
thanks in advance and have a nice day
Router A
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-128 name=profile1
/ip ipsec peer
add address=192.168.40.172/32 name=peer2 profile=profile1
add address=192.168.40.171/32 name=peer1 profile=profile1
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=proposal1
/ip ipsec identity
add peer=peer1
add peer=peer2
/ip ipsec policy
add dst-address=192.168.11.0/24 peer=peer1 proposal=proposal1 src-address=192.168.10.0/24 tunnel=yes
add dst-address=192.168.12.0/24 peer=peer2 proposal=proposal1 src-address=192.168.10.0/24 tunnel=yes
Router B
/ip ipsec profile
/ip ipsec peer
add address=192.168.40.170/32 name=peer1 profile=profile1
/ip ipsec proposal
/ip ipsec identity
add peer=peer1
/ip ipsec policy
add dst-address=192.168.10.0/24 peer=peer1 proposal=proposal1 src-address=192.168.11.0/24 tunnel=yes
Router C
/ip ipsec profile
/ip ipsec peer
/ip ipsec proposal
/port
set 0 name=serial0
/ip ipsec identity
add peer=peer1
/ip ipsec policy
add dst-address=192.168.10.0/24 peer=peer1 proposal=proposal1 src-address=192.168.12.0/24 tunnel=yes
pashew
Re: IPsec ping through Main Server
Wed Nov 23, 2022 8:58 am
is there anyone who can help me?
sindy
Wed Nov 23, 2022 10:26 am
When you add B<->C policies to B,C, and A, the B<->C ping does go through A. So what is the actual concern?
pashew
Wed Nov 23, 2022 11:28 am
when I want to ping from B to C, I want to be though A
the IPsec connection must be between A to B and A to C, there is no IPsec between B and C.
sindy
Wed Nov 23, 2022 11:49 am
That's correct, there will be no direct Security Association ("tunnel") between B and C. The B<->C policy between A and B will deliver packets for C from B to A, and the B<->C policy between A and C will deliver them from A further to C.
pashew
Wed Nov 23, 2022 12:13 pm
thanks for your support, could you give me more details, please?
sindy
Re: IPsec ping through Main Server  [SOLVED]
Wed Nov 23, 2022 2:38 pm
On A, add two policies:
dst-address=192.168.11.0/24 peer=peer1 proposal=proposal1 src-address=192.168.12.0/24 tunnel=yes
dst-address=192.168.12.0/24 peer=peer2 proposal=proposal1 src-address=192.168.11.0/24 tunnel=yes
On B, add one policy:
dst-address=192.168.12.0/24 peer=peer1 proposal=proposal1 src-address=192.168.11.0/24 tunnel=yes
On C, add one policy:
pashew
Wed Nov 23, 2022 5:17 pm
Dear sindy, many thanks for your support it's working.
it is amazing that you are supporting all people, thanks again.
Users browsing this forum: Bing [Bot], codi639, elbob2002, gdanov, jamesperks and 125 guests
