uberdome
How to Add Latency for Testing?
Wed Nov 23, 2022 4:10 am
I want to add latency for testing purposes. I imagine one of the queue types could be configured to induce latency, but I do not have a solution figured out yet. I'd like to be able to introduce round trip delay adjustable from 5ms to 500ms.
Any suggestions? I don't actually want speed limited, just the time delay introduced.
Thank you, Chris
nichky
Re: How to Add Latency for Testing?
Wed Nov 23, 2022 6:53 am
i got one to simulate timeout:
add action=drop chain=input nth=2,1 protocol=icmp src-address=x.x.y.y
not sure whether is possible to increase the latency
sindy
Wed Nov 23, 2022 10:42 am
You need a linux machine for that. The tool to use is netem. To introduce a 500 ms delay for a 1 Gbit/s stream in one direction, you have to store 500 Mbits, i.e. roughly 50 Mbytes, of data in the queue. So on a device with enough RAM, you may be able to achieve this using containers (currently available only on arm, arm64, and x86 CPU architectures in ROS 7).
Buckeye
Forum Veteran
Forum Veteran
Wed Nov 23, 2022 7:42 pm
linux has tc netem available, but I don't know if MikroTik exposes it (without a container as @sindy mentioned)
Here are some links with documentation.
https://wiki.linuxfoundation.org/networking/netem
Linux Traffic Control WAN Emulation
Using Linux NetEm to emulate a network
Simulating Network Latency, Bandwidth and Packet Loss with a Raspberry Pi
chechito
Thu Nov 24, 2022 12:03 am
try limiting traffic below the normal speed you achieve with a simple queue using a queue type with a very big size (take in count memory available on the router)
uberdome
Fri Nov 25, 2022 7:22 pm
Thank you very much - NetEm provides the exact functionality I was looking for!
It would be nice if it was exposed in RouterOS, but I'll just setup a separate system for it for now.
Users browsing this forum: Bing [Bot], Extrems, infabo, llamajaja, sas2k and 75 guests
