murdinger
Hotspot Script Active User Problem
Thu Nov 24, 2022 2:55 am
Hello, since i cant make work out the script that i found on the forum, i am asking for help.
Im using FreeRadius and i have to guarantee only one simultaneous user in Hotspot Active Users with a script that runs every minute on the router.
My RB1100 is using RouterOS V7
Scipt:
:local uname $user;
:local usercount 0;
:local usertime "00:00:00";
:local kickable;
:local maxuser 1;
:foreach i in=[/ip hotspot active find user=$uname] do= {
  :local curup [/ip hotspot active get $i uptime];
  :if ( $curup > $usertime ) do={
        :set usertime $curup
        :set kickable $i
  :set usercount ($usercount+1)
:if ($usercount >= $maxuser) do={
  :log info "Login user: $uname ($usercount/$maxuser) - Oldest $usertime will be logout!"
  /ip hotspot active remove numbers=$kickable
} else {
   :log info "Login user: $uname ($usercount/$maxuser)"
binooetomo
Re: Hotspot Script Active User Problem
Sat Mar 11, 2023 9:59 am
Did you solve the problem?
what FreeRadius module you used?
Basicaly, your FreeRadius have to include 'reply:Port-Limit' in it's response to the radius client.
reff: https://wiki.mikrotik.com/wiki/Manual:R ... ess-Accept'
-bino-
Users browsing this forum: No registered users and 93 guests
