ilunne
The Dude graph over 7Gbps
Fri Nov 25, 2022 1:10 am
when the measured bandwidth exceeds 7Gbps, the graph becomes inconsistent and presents values ​​as if 7Gbps were subtracted from the equation. For example: If the measured value is 9Gbps, 2Gbps will be drawn. Is it possible to fix this?
chechito
Re: The Dude graph over 7Gbps
Fri Nov 25, 2022 5:09 am
what version of RouterOS are you using? im on 6.48.6 and graphic suffer that around 3gb+
holvoetn
Fri Nov 25, 2022 11:23 am
Shoot ticket to support.
It's not certain they read this forum for bug-reports.
And yes, they will also ask which version you're running.
stmx38
Long time Member
Long time Member
Sat Nov 26, 2022 2:07 pm
Something similar already mentioned in Dude v6/v7 - Known bugs.
Users browsing this forum: No registered users and 45 guests
