pierrer
Voice Parameter SWOS
Fri Nov 25, 2022 9:32 am
Hi
I'm new to SWOS. I have used HP Switches in the past.
Normally on HP I have assigned a voice parameter to the voice vlan so the switch will automatically know to add the phone to the voice vlan.
The mitel phones have an extra ether port to connect your PC to. The phone will connect to the switch and the PC will connect to the Mitel Phone.
The PC will receive be on the Data Vlan and the phone on the Voice Vlan.
With the Mikrotik SWOS I don't see an option to assign a voice parameter to the voice vlan.
I have to manually add the vlan ID on the Mitel under its settings.
Then only will the phone and PC be able to receive IP's from the correct Vlans.
Just wanted to know if there's such a setting on SWOS?
Regards
BartoszP
Re: Voice Parameter SWOS
Sat Nov 26, 2022 1:06 am
...Normally on HP I have assigned a voice parameter to the voice vlan so the switch will automatically know to add the phone to the voice vlan....
Could you elaborate e liitle more on that? What is "Voice Parameter"?
chechito
Sat Nov 26, 2022 1:55 am
MikroTik does not provide that función (auto voice vlan) built in, maybe using rules (ACL) You can get something like that
cfikes
Sat Nov 26, 2022 4:34 pm
If your switch is capable of running RouterOS, like a CRS series and not a CSS series, they do support voice vlan assignment using lldp-med. It has worked for me on the 3xx series using the new bridge model.
https://help.mikrotik.com/docs/display/ ... figuration
Users browsing this forum: No registered users and 40 guests
