stybyk
RB5009UPr+S+ SFP module not working
Sat Nov 26, 2022 4:34 pm
I have SM optics line 138 m between RB5009UPr+S+ and RRB962UiGS-5HacT2HnT both ROS 7.6 / firmware upgraded.
Both sides have manual ethernet 1 Gbit speed, a full duplex.
I tried 2 x SFP CISCO GLC-LH-SMD which have these parameters on the line:
RB5009
TX -7.135 dBm
RX -7.309 dBm
RRB962
TX -6.834 dBm
RX -8.887 dBm
RB962 shows the link OK up.
RB5009 flaps up/down every second, and module parameters are disappearing and appearing in winbox.
I tried also another brand module SPS-7110WCIS on both sides, same behavior.
I tried also some single fiber modules from MaxLink and the result same, always RB962 up, and RB5009 is not able to communicate.
Do I really need SFP from MikroTik to get the line working? Or is it a problem that I am using 10 Km module on the short-range?
Does it worth it to try ML-S31D-3 ( 3 Km SM SFP) or does it global problem on this RB with SFPs ?
//I discovered also that RB5009 must be rebooted always to load SFP information into winbox, otherwise, it is showing previously plugged SFP...
stybyk
Re: RB5009UPr+S+ SFP module not working
Tue Nov 29, 2022 2:52 pm
Update:
MaxLink ML-S31D-3 revision A just arrived.
Manufacturing date: 21-11-22 so brand new SFPs and the same behavior.
RB5009 flaps, RRB962UiGS no problem.
Test with the same SFP and Media convertor TPLINK MC220L <> towards RRB962UiGS , link was up and working.
stybyk
Thu Dec 01, 2022 2:09 pm
update on the case:
I bought mikrotik sfps S-31DLC20D no any change, still port flaping on RB5009.
I have a suspicion that devices really don´t like each other :shock: :lol:
As I tried that TPLINK media converter.
ETH1 RB5009 - media converter >>> fiber >>>> SFP1 RB962 - works no mather on sfp type in converter or RB
SFP1 on RB5009 ->> fiber >>> media converter ETH2 RB962 - works , works no matter on SFP type in converter or RB !! also with cisco SFP in RB5009
The idea of downgrade RB962 to 6.49.7 also no any change. RB5009 flapping stil.
Mikrotik guys, please help !!!
pcunite
Fri Dec 02, 2022 5:38 am
I like the generic FS.com modules.
prmfeddema
Mon Dec 05, 2022 12:55 pm
Similar problem here with FS.com modules (which work fine in a HexS) - for now the R5009 is just a very expensive paper-weight....
stybyk
Mon Dec 05, 2022 1:32 pm
If that problem would be just about the exotic type of SFPs like cisco I say nothing, but as this is the same even I bought MikroTik, that really annoying me.
Even worse that I still didn´t receive any basic reply from Mikrotik.
Hi, can you also describe your problem like me?
What are your connected devices, versions, sfp type?
Sent it also with a support file to Mikrotik maybe you will have better luck and they will look at your case.
brg3466
Tue Dec 06, 2022 4:33 am
I have the same issue.
RB5009 UPr <--> CRS328-24P ,connected by 3m-long Mikrotik DAC.
I found sfp+ interface on RB5009UPr down randomly. Status showed within 48 hours, it was down 11 times.
Before RB5009, I use CCR1009-7G-1C-1S+ and sfp+ interface never down, so I suspect it is related to RB5009.
stybyk
Fri Jan 27, 2023 12:23 pm
does anyone receive response from mikrotik ?
I found that in 7.8beta2
*) sfp - fixed false link detection with S+RJ10 on RB5009;
Release 7.7rc5
*) sfp - added 2.5G SFP module support for RB5009;
But something like S-31DLC20D 1G single mode still not working :( it really bothers me, that it´s not working on a relatively great device. ( with a lot of other problems but with so big impact like this one)
mada3k
Forum Veteran
Forum Veteran
Sun Jan 29, 2023 6:42 pm
Tried setting static speed/duplex and disable auto-nego?
Gnits
Tue Jan 31, 2023 3:08 am
I have had a ticket in on mine for 3 weeks.
stybyk
Tue Jan 31, 2023 11:33 am
Yes, not even going up without this setup. But RB5009 flapping cca 3 times per second :D
stybyk
Fri Mar 10, 2023 1:44 pm
Update regarding to:
ROS Release 7.8
*) sfp - fixed reading of SFP EEPROM on single SFP port devices;
*) sfp - improved optical modules SFP compatibility on CCR2004-16G-2S+, CCR2004-1G-12S+2XS, CCR2116-12G-4S+ devices;
Tried all types of SFPs again from MikroTik, dlink, cisco.. All same, disappearing and appearing every 2 seconds..
No progress yet.
brg3466
Fri Mar 10, 2023 8:44 pm
I recently tried 7.8rc3, with fs.com product, and it seems very stable. RB5009 <-> CRS328. No single drop ever since.
stybyk
Tue May 02, 2023 7:09 pm
New update:
RB962UiGS-5HacT2HnT ROS 7.8 + same firmware
RB5009UPr+S+ ROS 7.9 + firmware upgraded
*) sfp - added log warning about failed auto-initialization on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - allow modules that hold "TX_FAULT" high signal all the time on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - allow modules with bad or no EEPROM in forced mode on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices
*) sfp - improved module initialization and display more detailed initialization status on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - improved system stability with some SFP GPON modules on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-
Same SFP on both sides, RB5009 still flapping.
stybyk
Fri Jul 14, 2023 12:33 pm
It is 245 days after my workaround opti convertor installation while waiting to mikrotik resolve issue on the 1G sfp :( :o Still same problem and even original mikrotik sfp is not abble to comunicate and flaping in the RB5009.
stybyk
Sat Oct 28, 2023 12:10 pm
there is still no solution for the RB5009 <> RB962UiGS-5HacT2HnT 1g SFP connection even on the version 7.11.2
SFP flaping 2 times per second on the RB5009.
Do someone have RB5009 some type of 1G SFP working ? Or does mikrotik team focus only to solve 10G request for the RB5009 and 1G is still in development even after almost 2 yaears after the hardware release !!
I want to remind that ORIGINAL MIKROTIK 1G SFP IS NOT WORKING ON THE ROUTER after 2 years !!!! :shock: :shock: :shock: :shock:
dcavni
Sat Oct 28, 2023 2:20 pm
I'm using Mikrotik's DAC cable to connect from 5009 to 24 port Zyxel switch at 1 Gbps (ports on Zyxel are only 1 Gbit). 39 days uptime and zero disconnects.
Not sure if this information is helping you in any way.
https://mikrotik.com/product/xs_da0001
stybyk
Sat Oct 28, 2023 2:59 pm
Yes, 10G and 1 G DAC are confirmed that works. But i need connection for 180 meters.
Unfortunately DAC out of range here.
Urd
Sat Oct 28, 2023 7:04 pm
I have RB5009 with QSFPTEK Gigabit SFP to RJ45 working with no issues more than year on both ROS 7.0.5 (factory preinstalled) and 7.11.2.
stybyk
Thu Nov 30, 2023 6:50 pm
new findings about that SFP problem !!
Today finally some lucky situation haappened and my friend borowed me new L009UiGS-2HaxD-IN.
And guess what happened, SFP on RB5009 stoped flapping and finally get stable data transfer.
So finally i have at least some chance to resolve it by new router on the opposite side. But I would still like to solve the current problem.
I know that RB962UiGS-5HacT2HnT is pretty old device, but still suitable for the purpose of the technically 1G L2 transfere on the fiber range.
So current summary.
RB962 <> RB5009 FLAP
RB962 coper TP-LINK MC220L <fiber> RB5009 FLAP
RB962< fiber > TP-LINK MC220L < coper > RB5009 OK
L009 < fiber > RB5009 OK
