jaxed8
Create/update address-list from a .txt file/link IPs and add the hostname to the comment's of each
Sat Nov 26, 2022 5:43 pm
Hello everyone
I was wondering if there is a script for resolving and adding all the IPs of the websites which are on a link (example: https://test.com/sitelist.txt) to a address-list and add the host name as comment to the first IP of each website.
Example: Link/txt file is containing the following:
google.com
yahoo.com
android.com
apple.com
then the script resolve those addresses to find their IPs, then it will add them as following to the address-list:
add address=123.123.123.123 comment=google.com list=scan
add address=123.123.123.124 list=scan
add address=123.123.123.125 list=scan
add address=78.16.85.1 comment=yahoo.com list=scan
add address=124.15.21.110 comment=android.com list=scan
add address=124.15.21.120 list=scan
add address=141.165.84.125 comment=apple.com list=scan
Jotne
Re: Create/update address-list from a .txt file/link IPs and add the hostname to the comment's of each
Sat Nov 26, 2022 6:46 pm
Why do you like to do that. To try to block some?
Google etc changes IP all time and gives different IP depending location etc.
jaxed8
Sat Nov 26, 2022 8:27 pm
Not blocking them but to bypass the traffic from VPN tunnel.
google was only an example, the list is full of websites that mostly have only 1 IP.
jaxed8
Mon Nov 28, 2022 1:15 pm
Any idea/solution?
BartoszP
Mon Nov 28, 2022 1:35 pm
You should read this topic:
viewtopic.php?p=606832#p606832
vklpt
Tue Nov 29, 2022 6:41 pm
Any idea/solution?
You can literally add hostnames to address-list and they are will be resolved automatically.
jaxed8
Wed Nov 30, 2022 1:59 am
Yeah that's totally right but in that case router is gonna query them every few minutes and spam up all my pi-hole query list.
jaxed8
Mon Dec 05, 2022 3:01 am
Thanks man but I didn't get how to use it, would you be so kind and elaborate it?
jaxed8
Thu Dec 15, 2022 9:31 pm
Up!
rextended
Fri Dec 16, 2022 3:56 pm
Open the file in an advanced text editor which allows advanced search and replace of one text block.
example file code
google.com¶
yahoo.com¶
android.com¶
apple.com¶
search only "¶" / "return" / "new line" / "enter" / \n / \r\n, or what is that "button" called in your country,
and replace with
replace code
"; :execute "/ip firewall address-list add address=[:resolve $site] comment=$site list=scan"
:local site "
Fix first and last line.
You obtain the script:
script code
:local site "google.com"; :execute "/ip firewall address-list add address=[:resolve $site] comment=$site list=scan"
:local site "yahoo.com"; :execute "/ip firewall address-list add address=[:resolve $site] comment=$site list=scan"
:local site "android.com"; :execute "/ip firewall address-list add address=[:resolve $site] comment=$site list=scan"
:local site "apple.com"; :execute "/ip firewall address-list add address=[:resolve $site] comment=$site list=scan"
Speaking of doing it with scripts in RouterOS, it's just not worth it to me.
Users browsing this forum: No registered users and 80 guests
