haris013
CHR 7.6 firewall issues
Sun Nov 27, 2022 9:22 pm
Hello, i have installed a chr on cloud vm and i am trying to create some firewall rules in order to secure my router.
my problem is that my rules doesn't work, it seems like they get bypass!! for example ssh and winbox are allowed while i have an input rule to drop everything from wan. also my bruteforce rules are not "catching" packets, they should count traffic these rules.
bellow is my config:
set [ find default-name=ether1 ] disable-running-check=no
add name=LAN
add name=WAN
/port
set 0 name=serial0
set discover-interface-list=none
/ipv6 settings
set disable-ipv6=yes
add interface=ether1 list=WAN
add address=5.XXXX.XXXX.196/24 interface=ether1 network=5.XXX.XXX.0
/ip dhcp-client
add disabled=yes interface=ether1
set servers=XXXXXXXXX,XXXXXXX
add action=add-src-to-address-list address-list="port scanners" \
    address-list-timeout=2w chain=input comment="Port Scanners to list" \
    protocol=tcp psd=21,3s,3,1
    address-list-timeout=2w chain=input comment="NMAP FIN stealth scan" \
    protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
    address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" protocol=\
    tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    address-list-timeout=2w chain=input comment="ALL/ALL scan" protocol=tcp \
    tcp-flags=fin,syn,rst,psh,ack,urg
    address-list-timeout=2w chain=input comment="NMAP NULL scan" protocol=tcp \
    tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
    address-list-timeout=2w chain=input comment="SYN/FIN scan" protocol=tcp \
    tcp-flags=fin,syn
    address-list-timeout=2w chain=input comment="SYN/RST scan" protocol=tcp \
    tcp-flags=syn,rst
add action=jump chain=input comment="SYN Flood INPUT" connection-state=new \
    jump-target=syn-attack protocol=tcp tcp-flags=syn
add action=add-src-to-address-list address-list=bruteforce_blacklist \
    address-list-timeout=1d chain=input comment=Blacklist connection-state=\
    new dst-port=1026,8292 protocol=tcp src-address-list=connection3
add action=add-src-to-address-list address-list=connection3 \
    address-list-timeout=1h chain=input comment="Third attempt" \
    connection-state=new dst-port=1026,8292 protocol=tcp src-address-list=\
    connection2,!secured
add action=add-src-to-address-list address-list=connection2 \
    address-list-timeout=15m chain=input comment="Second attempt" \
    connection1
add action=add-src-to-address-list address-list=connection1 \
    address-list-timeout=5m chain=input comment="First attempt" \
add action=accept chain=input comment="bruteforce ssh&winbox" disabled=yes \
    dst-port=1026,8292 protocol=tcp src-address-list=!bruteforce_blacklist
add action=accept chain=input comment="WG VPN Rule" dst-port=13231 protocol=\
    udp
    established,related,untracked
    invalid
add action=drop chain=input src-address-list="port scanners"
add action=drop chain=input comment="defconf: drop all not coming from LAN"
add action=jump chain=forward comment="SYN Flood FW" connection-state=new \
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=syn-attack connection-state=new limit=400,5:packet \
add action=drop chain=syn-attack connection-state=new log=yes log-prefix=\
    SYN-ATK protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
    WAN
/ip firewall raw
add action=drop chain=prerouting dst-port=53 in-interface-list=WAN log=yes \
    log-prefix="WAN DNS" protocol=udp
add dst-address=0.0.0.0/0 gateway=5.XXXX.XXXX.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=1026
set api disabled=yes
set winbox port=8292
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Amsterdam
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
what i am configuring wrong? why firewall is not working properly? i have only 1 interface ether1 and is in WAN interface list. the accept input rule for winbox and ssh it is disabled but still i can connect. i have tried to clear connection tracker and reboot the chr.
jvanhambelgium
Forum Veteran
Forum Veteran
Re: CHR 7.6 firewall issues
Sun Nov 27, 2022 9:39 pm
So, what is this rule suppose to do ?
So you ARE allowing SSH + Winbox to your router if they are NOT the bruteforce_blacklist.
Why not make such filter rules and ONLY ALLOW IP's that *are* on a specific white-list of trusted public IP's ?
haris013
Sun Nov 27, 2022 9:43 pm
disabled=yes :) and it is still allowing connections.
mkx
Sun Nov 27, 2022 9:44 pm
The rule is disabled. But yes, it's not clear what was the firewall config when @OP did the vetification ...
anav
Sun Nov 27, 2022 11:43 pm
Fixed the horrible firewall settings!!
However you have to make sure you can reach the CHR for configuration purposes, assuming you have something set up ???
If not how do you reach it.
I am hoping something smart like Wireguard.
By the way you have no LAN of any sort on the CHR right??
To reach winbox you need access to the input chain, so for example I would come into the router via wireguard,
I would use SSH to reach my VM but to reach the router I would use WG and perhaps SSH as a backup.
You also need to have an interface attached to /tool mac-server mac-winbox
By the way, no clue as to why you think you need bloated firewall rules.
Are you running servers as there is none indicated on your config??
add action=accept chain=input in-interface=wg-interface src-address-list=authorized  { for future wireguard access to chr }
add action=accept chain=input  src-address=SSH address??? dst=port=winboxport  protocol=tcp { for current SSH connection }
add action=drop chain=input comment="drop all else"
add action=accept chain=forward comment="allow internet traffic" in-interface=wg-interface out-interface-list=WAN  { for future access to internet from wg clients }
add action=drop chain=forward  comment="drop all else"
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
/ip service
set ssh port=1026   {  i usually never publish my ssh port !! }
set winbox port=xxxxxxx  { i usually never publish my winbox port !! }
/ip ssh
/system clock
set enabled=no
/tool mac-server
set allowed-interface-list=ADMIN
add name=ADMIN
/interface list members
add interface=wg-interface  list=ADMIN
add interface=SSH  list=ADMIN
haris013
Mon Nov 28, 2022 11:28 am
/ip service
/ip ssh
/system clock
set enabled=no
/tool mac-server
add name=ADMIN
Hello, thanks for the info!
I will use wireguard to create a few site2site VPNs and also i will manage the chr through SSH and WG.
I have no LAN on CHR, only 1 WAN and a WG that i will create and use it as relay VPN server.
Also why i need to have an interface attached to /tool mac-server mac-winbox? is it not a security issue?
Can you explain me why my rules didn't work and what was the mistake in order to learn?
thanks again!
Users browsing this forum: Google [Bot], phascogale and 39 guests
