chuq
LAN Interface static ip
Sun Nov 27, 2022 10:21 pm
I've removed ether5 from lan bridge, and assigned 192.168.88.5 ip to it
But I can't connect to this ip from my pc, and in there is an "ether5 unreachable" message in the routes list gateway col.
Where I'm wrong ?
BartoszP
Re: LAN Interface static ip
Mon Nov 28, 2022 8:19 am
What IP has your computer?
No DHCP on that interface means no traffic if your computer is not manually configured.
chuq
Mon Nov 28, 2022 12:00 pm
My pc has been also configured with static ip from the same network (say 192.168.88.7), but they didn't see each other.
The problem disapeared when I switched them to another net (not the default one 192.168.88.0)
mkx
Re: LAN Interface static ip  [SOLVED]
Mon Nov 28, 2022 2:42 pm
You can't have[*] router member of two IP subnets that have same network address ... e.g. you can't have 192.168.88.1/24 on bridge and 192.168.88.1/24 on ether5 ... router doesn't know which of the two subnets have to be used to access another device member of one of these two subnets. This is networking basics.
[*] It is possible to actually make it happen, but the setup is pretty awkward and not for the faint of heart. So just don't try to do it.
Users browsing this forum: GoogleOther [Bot] and 49 guests
