antleo
X710 SR-IOV VF not recognized as a NIC in CHR
Mon Nov 28, 2022 2:48 pm
Hey all,
I set up a new CHR with an x710 VF as it's NIC. However, the NIC is not recognized. They show up in System > Resources > PCI and are marked as Intel Corp Ethernet Virtual Function 700 Series (rev: 2), but don't show as ethernet interfaces. Is there a step I missed for getting this to work? CHR 7.6 on proxmox 7.2.7.
Thanks!
nz_monkey
Re: X710 SR-IOV VF not recognized as a NIC in CHR
Tue Nov 29, 2022 12:47 am
I am certain that this used to work.
So, your best bet is to contact Mikrotik support through the web-portal or by emailing support@mikrotik.com
antleo
Mon Dec 05, 2022 10:01 pm
For those curious, I did open a support ticket (SUP-99556)
I'll report back once I have an update.
dominiaz
Sun Dec 11, 2022 10:33 am
I have the same and SR-IOV also doesnt work for me.
SR-IOV is working fine only on Mikrotik 7.1. It doesn't work anymore on Mikrotik versions 7.2 - 7.6.
Please fix it.
chubbs596
Tue Dec 13, 2022 11:51 pm
Please fix it.
Same issue here, and if I use iommu passthrough , the interfaces also does come up for some reason, also using Intel X710 cards
SuperMiao
Wed Dec 14, 2022 8:11 pm
x722 VF same
inteq
Tue Jan 10, 2023 6:11 am
I use X722 on ESXI 8 with VMXNET3 and get 10 Gbps with minimal CPU usage.
vswitch is out of the question or why you need SR-IOV?
Users browsing this forum: No registered users and 49 guests
