Techsystem
apply ping of death on my mikrotik RB951ui
Mon Nov 28, 2022 4:12 pm
Hello My friends..!
so i am trying to forcing my RB951ui to 100% CPU usage by applying a large ping packet size -65500 byte-
so i disable my default firewall rule and applied the ping test, but my CPU still around 20-30% so anyone know how to forcing my CPU to 100%.
do i have to ping using more than one PC..?
in this scenario i am only using my PC.
normis
Re: apply ping of death on my mikrotik RB951ui
Mon Nov 28, 2022 4:27 pm
Why :D ? Can you clarify your goal?
anav
Mon Nov 28, 2022 4:33 pm
Clearly to horrify the parents of said RB951ui :-)
normis
Mon Nov 28, 2022 4:36 pm
Well, looks like the MikroTik routers don't die so easily. Try to kill some other appliances instead :D
anav
Mon Nov 28, 2022 6:24 pm
How did Latvia Day Celebrations go?? Would love to partake someday.
Is it the best celebrations to plan a trip around?? I am learning about the history of Europe and thus far I am at the stage where the then Russian Empire invades Northward and defeats the Swedes in the Baltic States area - where the teutonic knights invaded way earlier and settled. Looking forward to learning how Baltic countries then appeared out of the ashes............
Techsystem
Mon Nov 28, 2022 7:49 pm
well actually i want to hack someone :D to force him to use my firewall security system..! but unfortunately recently i realized that he using RB1100 AH. so step by step i am trying now with
my little darling RB951ui. i know that you know Normis, but..well .. i will accept that your not going to tell me..
anav
Mon Nov 28, 2022 7:51 pm
Sounds illegal to me.
Users browsing this forum: mansuramir and 91 guests
