memo009525
DNS blocking hotspot status page !!!
Mon Nov 28, 2022 4:51 pm
Hey everybody .... I'm having a problem with hotspot status page that i can't access it ... so if there is anyone to help me I will be very grateful.
The problem is that I use this DNS
- 208.67.220.123
- 208.67.222.123
This DNS block porn sites it's working fine but when i'm trying to access hotspot status page so i can logout it doesn't popup it's tell me that proplem with DNS so i tried to change it to google DNS and it's working fine I was able to access the hotspot status page but i need the other DNS to block porn sites so if anyone know why this dns blocking status page or how i could access the hotspot status page when i'm using the following dns
- 208.67.220.123
- 208.67.222.123
I will appreciat that ... thank you
Sob
Re: DNS blocking hotspot status page !!!
Mon Nov 28, 2022 7:28 pm
/ip dns static
add type=FWD name=<hostname of your hotspot status page> forward-to=8.8.8.8
anav
Mon Nov 28, 2022 8:00 pm
OH NO................. explanation provided?
I was looking forward to how redirecting dns to 8.8.8.8 google, and thus bypassing the proper DNS for user protection, was going to work with that line of config ???????????????
Sob
Mon Nov 28, 2022 8:15 pm
Isn't it self-explanatory enough, as RouterOS config mostly is? If there's query for given hostname, it will be forwarded to 8.8.8.8 instead of to main servers in /ip dns.
memo009525
Mon Nov 28, 2022 10:52 pm
Thanks Sob i will try it out and tell you if it working or not .. thanks again
memo009525
Mon Nov 28, 2022 11:20 pm
Hey Sob i try it out but still show me same error when i'm tring to access the hotspot status page ... so what should i do now ?
Sob
Tue Nov 29, 2022 12:51 am
Sorry, my bad, I misundertood what you need. I thought you have router behind another hotspot, which sounded a bit weird... anyway, I was wrong. Unfortunately, I don't know much about RouterOS hotspot.
It seems that you want your users to use router as DNS resolver, to be able to resolve that hostname which points to 192.168.88.1. I'm guessing you give those two DNS servers to users? It would make sense that resolving your hostname doesn't work. But it should be the same with Google servers, because they are also external servers that can't know anything about your local hostname.
memo009525
Tue Nov 29, 2022 1:03 am
No problem bro ... all i want that get access to hotspot login/status page but the follwing DNS
- 208.67.220.123
- 208.67.222.123
which i'm using blocking me to access it ... i don't know why and when i change DNS to google DNS or any DNS it's working fine and show me the pages but i need this DNS to block porn sites thats all ... and thank you bro for helping me ❤️
Users browsing this forum: No registered users and 75 guests
