KWL
Onesided srever to client connection with wireguard
Tue Nov 29, 2022 10:37 am
I have mikrotik router with static IP and server in a different location being client in wireguard VPN connection. I set the connection up no problem, but I want to limit access from the client site to my network behind mikrotik. As of right now anyone logged on to server has full access to everything behind mikrotik. Can I limit what part of the network is accessible to remote users (maybe even to deny connection to any part of my network)? Current config below:
MT:
/interface wireguard
add listen-port=Z mtu=1420 name=wireguard2
/interface wireguard peers
add allowed-address=x.x.x.3/32 interface=wireguard2 persistent-keepalive=1m \
public-key="XXXXXXXXXXXX"
add address=x.x.x.2/32 interface=wireguard2 network=x.x.x.0
add action=accept chain=input dst-port=\
Z protocol=udp
Client:
[Interface]
PrivateKey = YYYYYYYYYYYYY
Address = x.x.x.3/32
DNS = 8.8.8.8
[Peer]
PublicKey = WWWWWWWWW
AllowedIPs = x.x.x.2/32
Endpoint = z.z.z.z:Z
PersistentKeepalive = 10
anav
Re: Onesided srever to client connection with wireguard
Tue Nov 29, 2022 4:06 pm
Draw a diagram of the network as the explanation was very confusing.
Sob
Tue Nov 29, 2022 5:32 pm
Generally, firewall filter is your friend, if you want to block something, then block it, or don't allow it in the first place. But even without it, it doesn't sound likely that client can access everything behind MT, because if it has only x.x.x.2/32 in allowed addresses, that's all that will pass through tunnel (in client->MT direction).
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], erlinden, Majestic-12 [Bot], reinerotto, TheCat12 and 74 guests
