petardo
DHCP server is pushing both internal and received dynamic IPs to clients
Wed Nov 30, 2022 1:03 pm
MT router behind provider's router receives dynamic DNS 192.168.0.1
MT router IP: 192.168.128.1
Settings:
/ip dns set allow-remote-requests=yes
/ip dns static add address=192.168.128.1 name=router.lan
/ip dhcp-server add address-pool=dhcp interface=bridge name=defconf
/ip dhcp-server network add address=192.168.128.0/24 comment=defconf gateway=192.168.128.1 netmask=24
All clients are getting both 192.168.0.1 and 192.168.128.1 as DNS servers.
To my understanding only the MT internal DNS address (192.168.128.1) should have been pushed.
I don't understand, pls help.
erlinden
Re: DHCP server is pushing both internal and received dynamic IPs to clients
Wed Nov 30, 2022 1:10 pm
I think it can be overwritten by setting DNS server in /ip dhcp-server network
petardo
Wed Nov 30, 2022 1:22 pm
It is not overwritten:
/ip dhcp-server network print
Columns: ADDRESS, GATEWAY
# ADDRESS           GATEWAY
;;; defconf
0 192.168.128.0/24  192.168.128.1
erlinden
Wed Nov 30, 2022 1:48 pm
I mean, the behaviour can be overwritten by setting the DNS server explicitely:
/ip dhcp-server network add address=192.168.128.0/24 dns-server=192.168.128.1 comment=defconf gateway=192.168.128.1 netmask=24
pe1chl
Wed Nov 30, 2022 2:10 pm
There is a separate checkmark "No DNS" to remove the automatic DNS servers from the list of DNS servers distributed via DHCP.
You can still distribute statically configured DNS servers.
petardo
Wed Nov 30, 2022 2:34 pm
Yes, thanks, that works, but it is then just a workaround, I would like to unterstand the behavior.
pe1chl
Wed Nov 30, 2022 6:06 pm
petardo
Wed Nov 30, 2022 11:07 pm
Thanks.
I had a look at my other installations, and I recognized that that pushing received or set DNS as secondary DNSs is the normal operation.
I was mistaken, sorry.
Users browsing this forum: Bing [Bot] and 118 guests
