javiertecla
problem creating sstp + win 7 + rb4011
Wed Nov 30, 2022 4:14 pm
good guys how are you? Query, could you guide me how to create an sstp type vpn please, I followed several guides but none have worked for me, I managed to create the certificate and install them but unfortunately it does not connect me. That's why I ask you if you can help me with a guide from 0 to be able to do it...
MickeyT
Re: problem creating sstp + win 7 + rb4011  [SOLVED]
Fri Dec 02, 2022 8:39 am
I haven't used an RB4011 but the attached PDF shows how I managed to get SSTP VPN working with RouterOS.
If you are using self-signed certificates then Windows 7 (actually, all Windows versions) will fail the connection due to an invalid certificate. In that case you will need to import the SSTP server public key and trust it; better still, use a supported CA like Let's Encrypt.
Users browsing this forum: No registered users and 38 guests
