juanmi113
Transparent PtP link
Wed Nov 30, 2022 4:47 pm
Hey new here, and noob in Mikrotik.
Im tring to make a PtP link between a ONT and a home router using two oldies LHG5 dishes. I set them up in bridge mode but i cant establish connection between the ISP ont and the router. I followed tutotials and i managed to establish the RF link, set their IP addres and not much more.
Here is a schema:
ONT ------ antenna A ~~~~~~~~~~~~ antenna B ------- Router
I need the link to be transparent so the router can take the IP from the ONT. The ONT is like a simple modem, it has an public IP addres.
Antenna 1 is set as bridge and Antenna 2 as Station Bridge. Ether1 and wlan1 are set as bridge in each antenna.
I made links as this with ubiquiti equipment but i remember it was easier
Any help would be appreciated
sindy
Re: Transparent PtP link
Thu Dec 01, 2022 7:56 am
Setting the wireless interface to bridge mode is not the same as bridging the Ethernet and wireless interfaces together, so that step may be missing. To get a more useful advice, post the export of the configuration of both LHG5.
juanmi113
Fri Dec 02, 2022 11:17 pm
i think i bridged eth and wlan. Here are the configs:
# dec/02/2022 22:11:38 by RouterOS 7.6
# software id = PSWE-FRMC
# model = RBLHG5nD
# serial number = 6F2C0676FD27
add fast-forward=no name=bridge_E
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyn channel-width=20/40mhz-XX \
    country="etsi 5.5-5.7 outdoor" disabled=no frequency=5680 frequency-mode=\
    superchannel mode=station-wds nv2-security=enabled ssid=punto1 tx-power=\
    22 tx-power-mode=all-rates-fixed wds-default-bridge=bridge_E wds-mode=\
    dynamic wireless-protocol=nv2
/interface wireless nstreme
set wlan1 enable-nstreme=yes
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add interface=bridge_E name=server1
/ip hotspot profile
add name=dhcp_pool0 ranges=\
    185.245.145.129-185.245.145.241,185.245.145.243-185.245.145.254
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge_E interface=ether1
add bridge=bridge_E interface=wlan1
/interface detect-internet
set detect-interface-list=all lan-interface-list=all
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
/interface wireless align
set audio-monitor=6C:3B:6B:97:E3:3D receive-all=yes
add address=192.168.1.21/24 interface=bridge_E network=192.168.1.0
/ip dhcp-client
add disabled=yes interface=bridge_E
/ip dhcp-relay
add dhcp-server=192.168.1.254 disabled=no interface=bridge_E name=relay1
add address=185.245.145.128/25 gateway=185.245.145.242
add action=masquerade chain=srcnat out-interface=bridge_E src-address=\
    10.10.10.0/24
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name="Enlace E"
# dec/02/2022 22:13:12 by RouterOS 7.6
# software id = 8U6V-VYW1
# model = RBLHG5nD
# serial number = 6D0A06CF0C7B
add admin-mac=6C:3B:6B:01:6F:FC auto-mac=no comment=defconf name=bridge_R
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-Ce \
    superchannel mode=bridge noise-floor-threshold=-110 nv2-security=enabled \
    ssid=punto1 tx-power=22 tx-power-mode=all-rates-fixed wds-default-bridge=\
    bridge_R wds-mode=dynamic wireless-protocol=nv2
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp_pool0 ranges=0.0.0.2-255.255.255.254
/routing bgp template
set default disabled=no output.network=bgp-networks
add bridge=bridge_R comment=defconf ingress-filtering=no interface=ether1
add bridge=bridge_R ingress-filtering=no interface=wlan1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.20/24 interface=wlan1 network=192.168.1.0
add action=masquerade chain=srcnat dst-address-list=192.168.1.0/24 \
    out-interface=bridge_R
/system clock
/system identity
set name="Enlace R"
mkx
Sat Dec 03, 2022 12:11 pm
On the first unit:
/interface wireless
superchannel mode=station-wdsstation-bridge nv2-security=enabled ssid=punto1 tx-power=\
You can also make station more willing to folliw AP (whatever AP does) by changing these properties: frequency=auto wireless-protocol=nv2-nstreme-802.11 ...
Also disable WDS on both devices (wds-mode=disabled), MT devices in PtP mode work best when using their proprietary mode (which is bridge <-> station-bridge).
In your particular use case I don't think it's wise to run DHCP server (ONT is supposed to give router IP address) nor DHCP client, just set IP addresses statically. Also construct firewall (on both units) for chain=input which will block any connection attempts to these two devices and only allow it from some certain IP address (so you'll have management access later). And use bridge interfaces to configure local IP address and everything else, when interfaces are bridged IP layer doesn't know anything about member ports, IP layer talks to bridge interface.
juanmi113
Sun Dec 04, 2022 8:09 pm
Thanks for the replies, but the router has not internet
I dont understand the firewall set up. I mean, if i bridged ether1 and wlan1 in both antennas, and they are linked in RF, why the router cannot receive the IP from the modem?
Here are the configs now:
# dec/03/2022 18:11:17 by RouterOS 7.6
# model = RBLHG5nD
/interface wireless
    superchannel mode=bridge nv2-security=enabled ssid=punto1 tx-power=22 \
add name=WAN
add name=LAN
/ip hotspot profile
/snmp community
/ip dhcp-client
/ip dhcp-relay
add action=accept chain=input
/system clock
/system identity
set name="Enlace E"
The other one:
# dec/03/2022 18:11:47 by RouterOS 7.6
# model = RBLHG5nD
/interface wireless
    superchannel mode=station-bridge noise-floor-threshold=-110 nv2-security=\
    enabled ssid=punto1 tx-power=22 tx-power-mode=all-rates-fixed \
add name=WAN
add name=LAN
/interface lte apn
/ip settings
/ipv6 settings
set auth=sha1,md5
add address=192.168.1.20/24 interface=bridge_R network=192.168.1.0
/system clock
/system identity
set name="Enlace R"
And the firewall ir correct?
https://postimg.cc/kBBkCfPs
mkx
Mon Dec 05, 2022 12:14 pm
Perhaps I don't understand the requirements correctly, but the antennas in bridge should be completely transparent to traffic passing between modem and router. And yes, router has to get IP address from modem. Both wireless bridge devices don't have to ... in fact it's best they are hidden from modem because you want to manage them from inside your own LAN. Hence suggestion to disable DHCP client and set IP address on both wireless bridge devices.
Users browsing this forum: Bing [Bot] and 86 guests
