zte189
Invalid IPSEC Policy (ROS 7.6)
Thu Dec 01, 2022 8:38 am
Hi all!
When I create an IPSEC policy, it goes into Invalid status. The subnet does not overlap, everything is exactly the same on the remote side and the policy has the correct status.
I noticed that if you change the subnet mask, for example, to /26, then the policy immediately changes the status from Invalid to normal.
Why is that?
ROS Version 7.6
quija
Re: Invalid IPSEC Policy (ROS 7.6)
Wed May 17, 2023 10:09 am
Same problem here in 7.9
x.x.x.x/24 <-> y.y.y.y/29 invalid
x.x.x.x/24 <-> y.y.y.y/28 valid
Did you resolve it?
abbio90
Mon May 22, 2023 9:53 am
i on ROS 7.9 use these subnets without problems /16 /21
Users browsing this forum: No registered users and 190 guests
