vsslava
l3HW vs Cluster IP
Thu Dec 01, 2022 9:33 am
Hi
I have a problem with cluster ip being available from other vlan (routing), in current vlan cluster ip is available anyway when option in switch chip on CRS317-1G-16S+ is enabled (/interface/ethernet/switch/set switch1 l3-hw-offloading=yes). When the option is enabled when the cluster ip goes from node 1 to node 2, the cluster ip becomes unavailable.
When L3 HW Offloading=no option is disabled, the cluster ip from node 1 to node 2 moves normally.
In L2 segment everything works without any difficulties.
Need some help.
mkx
Re: l3HW vs Cluster IP
Fri Dec 02, 2022 9:25 am
ROS v7.7beta9 (just released) includes this entry in change log:
*) l3hw - fixed host offloading in a case of MAC address change;
I guess it applies to your problem.
vsslava
Mon Dec 05, 2022 9:39 pm
Hi
Thank you very much, RouterOS 7.7beta9 solved the problem.
Users browsing this forum: CGGXANNX, holvoetn, kormenator and 198 guests
