Askel
Number interface in snmp
Thu Dec 01, 2022 10:06 am
How to renumber an interface in snmp?
tdw
Re: Number interface in snmp
Thu Dec 01, 2022 2:22 pm
SNMP typically reports an interface index provided by the underlying OS, or from how it has built its index whilst enumerating the interfaces. There is no mechanism with SNMP to change this.
Askel
Thu Dec 01, 2022 3:58 pm
Enumerating the interfaces in underlying OS
Numbering does not match.
tdw
Thu Dec 01, 2022 4:07 pm
The UI interface index is not the same, see what you get from /interface print oid - the final octet of the OIDs are the SNMP interface index.
Askel
Fri Dec 02, 2022 7:03 am
0 R name=.1.3.6.1.2.1.2.2.1.2.1
1 S name=.1.3.6.1.2.1.2.2.1.2.7
2 S name=.1.3.6.1.2.1.2.2.1.2.3
3 RS name=.1.3.6.1.2.1.2.2.1.2.4
4 S name=.1.3.6.1.2.1.2.2.1.2.5
5 R name=.1.3.6.1.2.1.2.2.1.2.2
6 R name=.1.3.6.1.2.1.2.2.1.2.10
7 RS name=.1.3.6.1.2.1.2.2.1.2.9
8 R name=.1.3.6.1.2.1.2.2.1.2.8
9 R name=.1.3.6.1.2.1.2.2.1.2.6
Can this be changed?
tdw
Fri Dec 02, 2022 3:45 pm
No directly. As mentioned before Mikrotik builds an index whilst enumerating interfaces - each new interface is assigned a sequentially increasing value which does not change.
It is odd that the ethernet interfaces are not sequential as they would be discovered after a factory reset and cannot be removed via the UI, for example:
RB750Gr2 ifIndex 1-5=ether1-5
RB850Gx2 ifIndex 1-5=ether1-5
RB960PGS ifIndex 1-5=ether1-5, 6=sfp1
RB3011UiAS ifIndex 1-5=ether1-5, 6=sfp1, 7-11=ether6-10
Users browsing this forum: Bing [Bot], GoogleOther [Bot], Hober, Majestic-12 [Bot], Maveick87Shaka, McSee and 97 guests
