glk70
SFP Vdsl module
Fri Dec 02, 2022 10:51 pm
HI
I'm going to setup a internet access via VDSL (200/20Mbits D/U)
the connection will not be via fiber, but via twisted pair, so I'll need a modem
Instead of using a poor modem I'd preferr to use an SFP VDSL module in a mikrotik router, like an HEX S.or better a RB2011UiAS-IN
does anybody have tested/is using such a solution ?
Is there any suggested SFP modem to be used in a mikrotik router ?
Is there any compatilbility list for SFP modems ?
Thank you verymuch for any information.
Gianluca
mistry7
Re: SFP Vdsl module
Fri Dec 02, 2022 10:58 pm
Needed VDSL Standard?
glk70
Re: SFP Vdsl module
Sat Dec 03, 2022 1:15 am
vdsl/2 needed
Provider declares availabe 200Up / 20down standard rates
glk70
Re: SFP Vdsl module
Fri Dec 09, 2022 5:35 pm
UP
no one ?
Njumaen
Re: SFP Vdsl module
Fri Dec 09, 2022 5:41 pm
SFP modules are known here for bad performance and unreliability…
I’m using the DrayTek Vigor 165 Modem with my customers. It supports 35b supervectoring mode up to 300Mbit.
llag
Re: SFP Vdsl module
Sat Dec 10, 2022 4:06 pm
vdsl/2 needed
I think that the VDSL SFP modules do not support 200Mb down, only up to 100Mb. The proscend 180T however worked fin on 100Mb. But 200Mb is not supported. 200Mb can actually be delivered using higher frequencies on the line (even shorter reach than the 100Mb variant) OR with line bonding (2 lines with 100Mb each + some specific bonding implementation in the modem.
As recommended before go for a traditional external modem and consult with your ISP for what is recommneded
Users browsing this forum: Bing [Bot], ChadRT, LdB, neko98 and 137 guests
