gallp1
OSPF/MPLS It works, but why ?
Sun Dec 04, 2022 12:49 am
Hi Everyone, I'm trying to learn MPLS.
Let's say we have a topology like this
this are the configs of PE routers
PE1
add name=C2
add name=loopback0
set [ find default-name=ether2 ] comment="PE1 to PE3 backbone" mtu=9000
set [ find default-name=ether3 ] comment="PE1 to PE2 backbone" mtu=9000
set [ find default-name=ether1 ] name=mgmt
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:E5:7E:C0:7B:54 name=C2SiteAtoC2SiteB remote-peer=10.0.0.2 vpls-id=1:1
add disabled=no l2mtu=1500 mac-address=02:57:90:76:33:CA name=C2SiteAtoC2SiteC remote-peer=10.0.0.3 vpls-id=1:2
/routing ospf instance
set [ find default=yes ] router-id=10.0.0.1
add bridge=C2 interface=ether6
add bridge=C2 interface=C2SiteAtoC2SiteB
add bridge=C2 interface=C2SiteAtoC2SiteC
set protocol=""
add address=10.0.0.1 interface=loopback0 network=10.0.0.1
add address=10.0.1.1/30 interface=ether2 network=10.0.1.0
add address=10.0.1.5/30 interface=ether3 network=10.0.1.4
/ip dhcp-client
add disabled=no interface=mgmt
/mpls ldp
set enabled=yes transport-address=10.0.0.1
/mpls ldp interface
add interface=ether2
add interface=ether3
/routing ospf interface
add interface=ether2 use-bfd=yes
add interface=ether3 use-bfd=yes
add interface=loopback0
/routing ospf network
add area=backbone network=10.0.1.0/30
add area=backbone network=10.0.1.4/30
add area=backbone network=10.0.0.1/32
/system identity
set name=PE1
/system logging
add topics=mpls
PE2
add name=bridge1
add name=loopback0
set [ find default-name=ether2 ] mtu=9000
set [ find default-name=ether3 ] mtu=9000
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:2C:73:A0:41:DB name=C2SiteBtoC2SiteA remote-peer=10.0.0.1 vpls-id=1:1
set [ find default=yes ] router-id=10.0.0.2
add bridge=bridge1 interface=C2SiteBtoC2SiteA
set protocol=""
add address=10.0.0.2 interface=loopback0 network=10.0.0.2
add address=10.0.1.10/30 comment="PE2 to PE3 backbone" interface=ether2 network=10.0.1.8
add address=10.0.1.6/30 comment="PE2 to PE1 backbone" interface=ether3 network=10.0.1.4
/ip dhcp-client
/mpls ldp
set enabled=yes transport-address=10.0.0.2
/mpls ldp interface
/routing bfd interface
add authentication-key=123456 interface=ether2 use-bfd=yes
add authentication-key=12345 interface=loopback0
add area=backbone network=10.0.0.2/32
add area=backbone network=10.0.1.8/30
/system identity
set name=PE2
PE3
add name=C2
add name=loopback0
set [ find default-name=ether2 ] comment="PE3 to PE1 Backbone" mtu=9000
set [ find default-name=ether3 ] comment="PE3 to PE2 Backbone" mtu=9000
/interface vpls
add disabled=no l2mtu=1500 mac-address=02:0A:27:87:33:7C name=C2SiteCtoC2SiteA remote-peer=10.0.0.1 vpls-id=1:2
set [ find default=yes ] router-id=10.0.0.3
add bridge=C2 interface=C2SiteCtoC2SiteA
add bridge=C2 interface=ether4
add address=10.0.0.3 interface=loopback0 network=10.0.0.3
add address=10.0.1.9/30 interface=ether3 network=10.0.1.8
add address=10.0.1.2/30 interface=ether2 network=10.0.1.0
/ip dhcp-client
/mpls ldp
set enabled=yes transport-address=10.0.0.3
/mpls ldp interface
add interface=loopback0 use-bfd=yes
add area=backbone network=10.0.0.3/32
/system identity
set name=PE3
/system logging
add prefix=MPLS topics=mpls
why am I able to ping 20.2.0.2 from 20.2.0.3
I was under the impression that I need a full VPLS mesh, but it works even when connection betwen PE1-PE3 is broken. What is going on there. How to DEBUG or view some more info in routerOS.
metrotyranno
Re: OSPF/MPLS It works, but why ?
Wed Dec 28, 2022 7:43 pm
As far as I am aware Mikrotik approaches the issue differently. The way you make multi-homed VPLS's in mikrotik is by creating a VPLS interface for each remote site, and adding them to a bridge. Because the VPLS's are added as ports on a bridge, they become switched. PE2 is switching the traffic over the bridge for you to PE3.
When making a full mesh VPLS in mikrotik you MUST have a layer2 loop prevention mechanism (spanning tree) or the bridges will sing :)
techkyle
Wed Jan 18, 2023 6:50 pm
Would split horizon be applicable for VPLS loop prevention in lieu of spanning tree?
Edit: Signs in Cisco documentation point to yes.
spippan
Wed Feb 22, 2023 9:37 am
Let's say we have a topology like this Zrzut ekranu_20221203_230043.png this are the configs of PE routers
can you transport data without VPLS here also? so from CE SiteA to CE SiteB, like, customer egress traffic?
Users browsing this forum: No registered users and 28 guests
