In the https://wiki.mikrotik.com/wiki/Manual:PCC setup page there is a routing command example:
Code: Select all
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
Code: Select all
check-gateway
Code: Select all
ping
Code: Select all
ip route
