merlinthemagic7
Wireless Broadcasts and Dynamic Vlans
Sun Dec 04, 2022 9:27 pm
We use radius to place wireless users in VLANs.
Question is: How is broadcast isolation maintained, when there are many different vlans in use on a particular BSSID?
Does MT use GTK for encrypting broadcasts?
We use "multicast-helper = full", so multicasts are converted to unicast and delivered using the TK, the question is purely about broadcasts.
A related question, if an AP only has connected clients belonging to VLAN 10, will the AP still use air time on broadcasts arriving on the wire from other VLANs?
mkx
Re: Wireless Broadcasts and Dynamic Vlans  [SOLVED]
Mon Dec 05, 2022 5:25 pm
Multicast-helper also works for broadcast packets (even though name of property doesn't mention it). As I understand it, when multicast helper is enabled, broadcast/multicast frames get sent only unicast to each AP client and are not also broadcasted.
merlinthemagic7
Fri Dec 09, 2022 12:20 am
It appears you are correct. Packet capture shows e.g. arp arriving at the AP as broadcasts but at the client as unicasts.
Thank you.
Users browsing this forum: GoogleOther [Bot] and 85 guests
