elico
REST API Creating and updating an ip firewall address list with domains
Sun Dec 04, 2022 11:28 pm
Hey,
I am using an external script to dump the DNS cache from the device and then populate an address list with specific domains.
I am able to dump and find the addresses but not sure how to add a batch of domains and/or addresses to the RouterOS device via REST API.
What:
should I use and also, what is the json content that should look like?
For example for "googlevideo" list the next domains:
rr3---sn-jjjpa-ua8e.googlevideo.com
rr3.sn-jjjpa-ua8e.googlevideo.com
rr1---sn-aigl6nzs.googlevideo.com
rr1.sn-aigl6nzs.googlevideo.com
elico
Re: REST API Creating and updating an ip firewall address list with domains
Mon Dec 05, 2022 12:09 am
OK so I took the time to write some code and give a programmatically example of an address-list update at:
https://github.com/elico/mikrotik-web-f ... ss-domains
It requires some environment variables like MT_HOST and MT_USER and MT_PASSWORD
I hope it helps someone.
elbob2002
Sat Dec 17, 2022 11:51 am
Thanks! I was just looking to do something similar this morning and came across this.
Users browsing this forum: No registered users and 36 guests
