Hi
I just got a new hap ax2 and have had a tough time trying to make this router work. The issues are as below:
The router doesn't broadcast the default Wifi which the quick start guide says it would.
I noticed the Wifi setting on the Quick Set page are all empty when I accessed the router using a cable.
The router lost all configurations after a reboot.
In the File tab on Winbox, it says there's 0% free space.
How should I start to troubleshoot? Thanks
