CheGeuv
My Wireguard on Phone is not working
Mon Dec 05, 2022 12:20 pm
Hi guy.
If anyone can help me for my wireguard connection.
I want to access my Mikrotik Router online with my phone.
here is my Router config, Wireguard interface, peer and android ss.
anav
Re: My Wireguard on Phone is not working
Tue Dec 27, 2022 10:20 pm
Remove the route you have added it is not required. -
add disabled=no dst-address=192.168.100.3/32 gateway=192.168.100.1 \
routing-table=main suppress-hw-offload=no
You will note the router already creates one for you from the IP address.
<dac> dst-address=192.168.100.0/234 gwy=wireguard1 table=main etc........
Other than that it should work, assuming on your phone you have set 0.0.0.0/0 as allowed IPs for the peer setting to the router.
Are you using MT app to access the router after connecting via wireguard?
CheGeuv
Wed May 03, 2023 4:21 pm
Yes, im using the MT app. Im using mobile data.
anav
Wed May 03, 2023 6:05 pm
set this to none
/interface detect-internet
set detect-interface-list=all
other than that minor item, should work
Users browsing this forum: No registered users and 67 guests
