AlohaSpark
Is there a way to get /tool/fetch response time?
Tue Dec 06, 2022 8:11 am
I would like to know how long it takes to fetch a URL. Is there a way to do so within a script?
rextended
Re: Is there a way to get /tool/fetch response time?
Tue Dec 06, 2022 11:30 am
unless you do it at the turn of midnight, if you memorize the time before the download and compare it with the time after the download...
Amm0
Tue Dec 06, 2022 7:49 pm
How about using :timestamp? While Mikrotik doesn't support dates or floats, they do have "time" and "time difference" type... Super useful here.
  :local start [:timestamp]
  /tool/fetch url="https://wttr.in/Riga+LV?T&format=2" output=user
  :local stop [:timestamp]
  :put ($stop-$start)
Which takes 3.1 seconds (or "00:00:03.103317400"), and we knows it's -2C & breezy in Riga, Latvia.
  status: finished
  downloaded: 0K
        data:               -2  C           20km/h
00:00:03.103317400
Amm0
Tue Dec 06, 2022 7:57 pm
Note: In theory, you might not want to use "output=user", and use "output=none" to time it. The output to display a relatively large amount of some time. In fact almost 2 second to write to terminal. And if you normally write to disk, timing it it that way be most accurate (output=file).
 { :local start [:timestamp]; /tool/fetch url="https://wttr.in/Riga+LV?T&format=2" output=none; :local stop [:timestamp]; :put ($stop-$start)}
      status: finished
  downloaded: 0KiBC-z pause]
       total: 0KiB
    duration: 0s
00:00:01.099018660
Users browsing this forum: No registered users and 37 guests
