sammy2022
Set a time limit for hotspot users - not uptime
Wed Dec 07, 2022 6:14 am
I am looking for a way to give a user 3 hours of access from the time they login. For example if the user logs in at 5:00pm they should be disconnected at 8:00pm and unable to reconnect after 8:00pm whether the uptime is actually 3 hours or not. Unfortunately setting uptime is not the solution as the user can disconnect after half hour and still have 2.5 hours if they connected at 8:00pm. I have used this feature in grase hotspot but cannot find how to achieve the same result with the Mikrotik hotspot.
Grateful for any assistance as I have purchased 3 devices to deploy in a similar scenario.
sammy2022
Re: Set a time limit for hotspot users - not uptime
Wed Dec 07, 2022 5:45 pm
Just an update. I found a solution using the validity option. I set the validity on the profile to be 3 hours and the data limit using a queue. This is now working as intended.
Users browsing this forum: GoogleOther [Bot], kormenator and 177 guests
