mfrabbibd
MANtbox 2 12s PtMP Max Distance
Thu Dec 08, 2022 11:29 am
Hi all, Hope all are well. Is there anyone who can tell me about MANtbox 2 12s PtMP Max Distance. I've 5 sets of MANtbox 2 12s. I'm planning one of them as AP and other 4 are like CPE. In that case, what would be the max distance from AP to CPE under clear line of sight? Please suggest me.
Regards.
mfrabbibd
Re: MANtbox 2 12s PtMP Max Distance
Fri Dec 09, 2022 10:33 am
Normis, would you please reply?
normis
Fri Dec 09, 2022 10:41 am
You will use Mantbox both as AP and also Mantbox as CPE?
Why not use CPE like SXTsq ?
1. They must both see each other (line of sight)
2. Elevation must be high enough (rooftop etc)
use calculator https://mikrotik.com/calculator
mfrabbibd
Fri Dec 09, 2022 11:54 am
Because I have mantbox 2 12s 5pcs on my hand. What would be the max distance in that case under clear Los.
Regards,
chechito
Fri Dec 09, 2022 7:50 pm
keep in mind because of the Sectorial Antennas you will pick up a lot of neighboring noise and 2ghz has a lot of noise nowadays
Zapy
Fri Mar 08, 2024 9:17 am
Will there be an updated calculator to support multi point?
Im currently looking for solution for this setup, would the mantbox ax be able to handle this?
i could do mantbox 12 as well, its for cameras so i have a bandwidth about 30 Mbps but would possible need to mount more cameras later on.
Users browsing this forum: saahil, sch and 104 guests
