karaYusuf
Why does the second script not run?
Thu Dec 08, 2022 4:35 pm
Hello everyone,
i made a script, which is swapping the functions of wlan1 and wlan2:
#swaping mac-address of wlan1 and wlan2
/interface/wireless
set [ find default-name=wlan1 ] mac-address=xxx
/interface/wireless
set [ find default-name=wlan2 ] mac-address=xxx
#disabling wlan1(2GHz) as station-mode
/interface/wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n \
    country=germany disabled=no frequency=auto mode=ap-bridge \
    installation=any default-authentication=yes \
    security-profile=default ssid=xxx
/interface bridge port add bridge=bridgeLAN interface=wlan1
/interface/wireless/connect-list/disable [find interface=wlan1]
/interface/list/member/remove [find interface=wlan1]
#enabling wlan2(5GHz) as station-mode
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    country=germany disabled=no frequency=auto \
    mode=station \
    default-authentication=no ssid="" \
    station-roaming=enabled installation=outdoor
/interface bridge port remove [find interface=wlan2]
/interface wireless connect-list
add interface=wlan2 signal-range=-75..120 allow-signal-out-of-range=1s connect=yes disabled=no security-profile=xxx ssid=xxx
/interface list member add list=WAN interface=wlan2
/ip/dhcp-client/remove [find interface=wlan1]
/ip/dhcp-client/add interface=wlan2
#automatisation for using lte-modem
/system script add dont-require-permissions=no name=wlan2-autoActivate owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
    if ([/interface print count-only where name=lte1] = 0) do={\r\
    \n /interface enable [find where name=wlan2];\r\
    \n} else={\r\
    \n:log info \"Error \";\r\
    \n}"
/system scheduler add interval=10s name=autoActivate on-event=wlan2-autoActivate start-time=startup
/system script add dont-require-permissions=no name=wlan2-autoDeactivate owner=admin policy=\
    if ([/interface print count-only where name=lte1] = 1) do={\r\
    \n /interface disable [find where name=wlan2];\r\
    \n} else={\r\
    \n}"
/system scheduler add interval=10s name=autoDeactivate on-event=wlan2-autoDeactivate start-time=startup
I just put that code in the files and use the import command to get the new settings..
So this is working on one specific hapac2-Router.
I decided to make this script working on every router pulling the mac-addresses of the wifi-interfaces and swapping them.
I came up with the following code:
#getting variables
:global getWlan2 [interface wireless get wlan2 ssid]
:global getMac1 [interface get wlan1 mac-address]
:global getMac2 [interface get wlan2 mac-address]
/interface/wireless
set [ find default-name=wlan1 ] mac-address=$getMac2
/interface/wireless
set [ find default-name=wlan2 ] mac-address=$getMac1
/interface/wireless
    security-profile=default ssid=$getWlan2
/interface wireless
    mode=station \
    \n} else={\r\
    \n}"
    \n} else={\r\
    \n}"
My problem is that this code just do not run. Giving me the same setting as I would have never used the import command. I do not see any syntax-mistakes.
It would be very great if there is someone knowing why it does not run.
Thank you for helping me.
rextended
Re: Why does the second script not run?
Fri Dec 09, 2022 12:40 am
You need one temporary MAC to swap MACs or when you set one identical MAC RouterOS you can lock or loop something...
# getting variables
/interface wireless
:global getMac1  [get [find where default-name=wlan1] mac-address]
:global getMac2  [get [find where default-name=wlan2] mac-address]
# prevent duplicate MACs when set on wlan1 the same MAC of wlan2
set [find where default-name=wlan2] mac-address=BA:DB:AD:BA:DB:AD
# swaping mac-address of wlan1 and wlan2
set [find where default-name=wlan1] mac-address=$getMac2
set [find where default-name=wlan2] mac-address=$getMac1
For the rest, I didn't understand anything.
Explain the end goal, not the intermediate steps....
karaYusuf
Wed Dec 14, 2022 11:56 am
# getting variables
/interface wireless
The rest is not understandable because the script on top is just an adding script to another script.
You solved my problem :) I thank you alot for your help and I am sorry for the late reply.
Users browsing this forum: No registered users and 25 guests
